NLM0011/ NLM0010 " NFC-PWM Series " NFC Wireless Configuration IC with PWM OutputFeatures • Configurable pulse width modulation (PWM) output • NFC contactless interface compliant to ISO/IEC 18000-3 mode 1 (ISO/IEC 15963) • Constant light output (CLO) with 8 configurable reference points • Integrated operation-time counter (OTC) and on/off counter • Non-volatile memory (NVM) including UID and 20 bytes free memory for user data Description The NLM0011 is a dual-mode NFC wireless configuration IC with PWM output. It is compatible with existing analog LED-driver designs and with the NFC-programming specification from the Module-Driver Interface Special Interest Group (MD-SIG). This device is primarily designed for LED applications to enable NFC programming. In addition, advanced features such as the constant lumen output (CLO) as well as the on/off counting are integrated, and there is no need for an additional microcontroller. Since the NLM0011 is designed to work together with mainstream analog driver ICs, there are no firmware development efforts needed. It can be easily adapted into existing designs to replace the “plug-in resistor” current configuration concept. The NLM0010 is a light version without CLO function. Datasheet Please read the Important Notice and Warnings at the end of this document 2.0 www.infineon.com 2019-05-31 Document Outline Features Description Table of contents 1 General 2 Feature Overview 3 Application Overview 4 Pin Description 5 Functional Description 6 Memory Organization 7 Application and User Memory Access Control 8 NLM0011/NLM0010 EEPROM Shipment Content (Infineon to Customer) 9 Constant Lumen Output (CLO) and Operating Time Counting (OTC) 10 PWM Overview 11 NLM0011/ NLM0010 Command Set 12 NLM0011/ NLM0010 Electrical Characteristics 13 Package Outline Revision history Disclaimer
