Datasheet TSOP22, TSOP24, TSOP48, TSOP44 (Vishay) - 2
ManufacturerVishay
DescriptionIR Receiver Modules for Remote Control Systems
Pages / Page7 / 2 — TSOP22.., TSOP24.., TSOP48.., TSOP44.. BLOCK DIAGRAM. APPLICATION …
File Format / SizePDF / 179 Kb
TSOP22.., TSOP24.., TSOP48.., TSOP44.. BLOCK DIAGRAM. APPLICATION CIRCUIT. ABSOLUTE MAXIMUM RATINGS PARAMETER. TEST CONDITION
TSOP22.., TSOP24.., TSOP48.., TSOP44. BLOCK DIAGRAM APPLICATION CIRCUIT ABSOLUTE MAXIMUM RATINGS PARAMETER TEST CONDITION
16833_14 17170-11 3 R1 Transmitter IR receiver 33 kΩ with VS + VS TSALxxxx C 1 1 μC Band Demo- OUT Input AGC Circuit pass dulator VO GND GND 2 PIN Control circuit R and C recommended to reduce supply ripple for V < 2.8 V 1 1 S
ABSOLUTE MAXIMUM RATINGS PARAMETER TEST CONDITION SYMBOL VALUE UNIT
Supply voltage VS -0.3 to +6 V Supply current IS 5 mA Output voltage VO -0.3 to 5.5 V Voltage at output to supply VS - VO -0.3 to (VS + 0.3) V Output current IO 5 mA Junction temperature Tj 100 °C Storage temperature range Tstg -25 to +85 °C Operating temperature range Tamb -25 to +85 °C Power consumption Tamb ≤ 85 °C Ptot 10 mW Soldering temperature t ≤ 10 s, 1 mm from case Tsd 260 °C
Note
• Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect the device reliability
ELECTRICAL AND OPTICAL CHARACTERISTICS
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Ev = 0, VS = 5 V ISD 0.55 0.7 0.9 mA Supply current Ev = 40 klx, sunlight ISH - 0.8 - mA Supply voltage VS 2.5 - 5.5 V Ev = 0, test signal see Fig. 1, Transmission distance IR diode TSAL6200, d - 24 - m IF = 50 mA I Output voltage low OSL = 0.5 mA, Ee = 0.7 mW/m2, V test signal see Fig. 1 OSL - - 100 mV Pulse width tolerance: Minimum irradiance tpi - 5/fo < tpo < tpi + 6/fo, Ee min. - 0.12 0.25 mW/m2 test signal see Fig. 1 t Maximum irradiance pi - 5/fo < tpo < tpi + 6/fo, E test signal see Fig. 1 e max. 50 - - W/m2 Angle of half transmission Directivity ϕ 45 - deg distance 1/2 - ± Rev. 1.8, 26-Sep-2018
2
Document Number: 82459 THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
