Datasheet 24C01C (Microchip) - 3
ManufacturerMicrochip
Description1K 5.0V I2C Serial EEPROM
Pages / Page36 / 3 — 24C01C. TABLE 1-2:. AC CHARACTERISTICS. Electrical Characteristics:. …
File Format / SizePDF / 981 Kb
24C01C. TABLE 1-2:. AC CHARACTERISTICS. Electrical Characteristics:. Param. Sym. Characteristic. Min. Max. Units. Conditions. No. (Note 1
24C01C TABLE 1-2: AC CHARACTERISTICS Electrical Characteristics: Param Sym Characteristic Min Max Units Conditions No (Note 1
link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3
24C01C TABLE 1-2: AC CHARACTERISTICS Electrical Characteristics: AC CHARACTERISTICS
Industrial (I): VCC = +4.5V to 5.5V TA = -40°C to +85°C Automotive (E): VCC = +4.5V to 5.5V TA = -40°C to +125°C
Param. Sym. Characteristic Min. Max. Units Conditions No.
1 FCLK Clock frequency — 100 kHz — — 400 (I-temp) 2 THIGH Clock high time 4000 — ns — 600 — (I-temp) 3 TLOW Clock low time 4700 — ns — 1300 — (I-temp) 4 TR SDA and SCL rise time — 1000 ns —
(Note 1 )
— 300 (I-temp) 5 TF SDA and SCL fall time — 300 ns —
(Note 1 )
6 THD:STA Start condition hold time 4000 — ns — 600 — (I-temp) 7 TSU:STA Start condition setup time 4700 — ns — 600 — (I-temp) 8 THD:DAT Data input hold time 0 — ns
(Note 2 )
9 TSU:DAT Data input setup time 250 — ns — 100 — (I-temp) 10 TSU:STO Stop condition setup time 4000 — ns — 600 — (I-temp) 11 TAA Output valid from clock — 3500 ns —
(Note 2 )
— 900 (I-temp) 12 TBUF Bus free time: Time the bus 4700 — ns — must be free before a new 1300 — (I-temp) transmission can start 13 TOF Output fall time from VIH 10 + 0.1CB 250 ns
(Note 1 )
minimum to VIL maximum CB  100 pF 14 TSP Input filter spike suppression — 50 ns
(Note 3 )
(SDA and SCL pins) 15 TWC Write cycle time (byte or — 1.5 ms — page) 1 (I-temp) 16 — Endurance 1,000,000 — cycles 25°C
(Note 4 ) Note 1:
Not 100% tested. CB = total capacitance of one bus line in pF.
2:
As a transmitter, the device must provide an internal minimum delay time to bridge the undefined region (minimum 300 ns) of the falling edge of SCL to avoid unintended generation of Start or Stop conditions.
3:
The combined TSP and VHYS specifications are due to new Schmitt Trigger inputs, which provide improved noise spike suppression. This eliminates the need for a TI specification for standard operation.
4:
This parameter is not tested but ensured by characterization. For endurance estimates in a specific application, please consult the Total Endurance™ Model, which can be obtained from Microchip’s web site at www.microchip.com.  1997-2012 Microchip Technology Inc. DS21201K-page 3 Document Outline 24C01C Features: Description: Block Diagram Package Types 1.0 Electrical Characteristics Absolute Maximum Ratings(†) TABLE 1-1: DC Characteristics TABLE 1-2: AC Characteristics FIGURE 1-1: Bus Timing Data 2.0 Pin Descriptions TABLE 2-1: Pin Function Table 2.1 SDA Serial Data 2.2 SCL Serial Clock 2.3 A0, A1, A2 2.4 Test 2.5 Noise Protection 3.0 Functional Description 4.0 Bus Characteristics 4.1 Bus Not Busy (A) 4.2 Start Data Transfer (B) 4.3 Stop Data Transfer (C) 4.4 Data Valid (D) 4.5 Acknowledge FIGURE 4-1: Data Transfer Sequence on the Serial Bus FIGURE 4-2: Acknowledge Timing 5.0 Device Addressing FIGURE 5-1: Control Byte Format 5.1 Contiguous Addressing Across Multiple Devices 6.0 Write Operations 6.1 Byte Write 6.2 Page Write FIGURE 6-1: Byte Write FIGURE 6-2: Page Write 7.0 Acknowledge Polling FIGURE 7-1: Acknowledge Polling Flow 8.0 Read Operation 8.1 Current Address Read FIGURE 8-1: Current Address Read 8.2 Random Read 8.3 Sequential Read FIGURE 8-2: Random Read FIGURE 8-3: Sequential Read 9.0 Packaging Information 9.1 Package Marking Information Appendix A: Revision History The Microchip Web Site Customer Change Notification Service Customer Support Reader Response Product Identification System Trademarks Worldwide Sales
