Datasheet PIC16F1764, PIC16F1765, PIC16F1768, PIC16F1769, PIC16LF1764, PIC16LF1765, PIC16LF1768, PIC16LF1769 (Microchip) - 8
ManufacturerMicrochip
Description14/20-Pin, 8-Bit Flash Microcontrollers
Pages / Page568 / 8 — PIC16(L)F1764/5/8/9. Table of Contents. 1.0 Device Overview . 10. 2.0 …
File Format / SizePDF / 9.6 Mb
PIC16(L)F1764/5/8/9. Table of Contents. 1.0 Device Overview . 10. 2.0 Enhanced Mid-Range CPU . 22. 3.0 Memory Organization . 24
PIC16(L)F1764/5/8/9 Table of Contents 1.0 Device Overview  10 2.0 Enhanced Mid-Range CPU  22 3.0 Memory Organization  24
PIC16(L)F1764/5/8/9
Table of Contents
4.0 Device Configuration . 62
5.0 Oscillator Module (with Fail-Safe Clock Monitor) . 70
6.0 Resets . 87
7.0 Interrupts . 96
8.0 Power-Down Mode (Sleep) . 111
9.0 Watchdog Timer (WDT) . 115
10.0 Flash Program Memory Control . 119
11.0 I/O Ports . 136
12.0 Peripheral Pin Select (PPS) Module . 154
13.0 Interrupt-On-Change . 162
14.0 Fixed Voltage Reference (FVR) . 169
15.0 Temperature Indicator Module . 172
16.0 Analog-to-Digital Converter (ADC) Module . 174
17.0 5-Bit Digital-to-Analog Converter (DAC) Module. 188
18.0 10-Bit Digital-to-Analog Converter (DAC) Module. 192
19.0 Comparator Module. 198
20.0 Zero-Cross Detection (ZCD) Module. 208
21.0 Timer0 Module . 214
22.0 Timer1/3/5 Module with Gate Control. 217
23.0 Timer2/4/6 Module . 228
24.0 Capture/Compare/PWM Modules . 250
25.0 10-Bit Pulse-Width Modulation (PWM) Module . 263
26.0 16-Bit Pulse-Width Modulation (PWM) Module . 269
27.0 Complementary Output Generator (COG) Module. 295
28.0 Configurable Logic Cell (CLC). 334
29.0 Operational Amplifier (OPA) Modules . 348
30.0 Programmable Ramp Generator (PRG) Module . 354
31.0 Data Signal Modulator (DSM) . 370
32.0 Master Synchronous Serial Port (MSSP) Module . 380
33.0 Enhanced Universal Synchronous Asynchronous Receiver Transmitter (EUSART) . 435
34.0 In-Circuit Serial Programming™ (ICSP™) . 465
35.0 Instruction Set Summary . 467
36.0 Electrical Specifications. 481
37.0 DC and AC Characteristics Graphs and Charts . 515
38.0 Development Support. 537
39.0 Packaging Information. 541
Appendix A: Data Sheet Revision History . 563
The Microchip WebSite . 564
Customer Change Notification Service . 564
Customer Support . 564
Product Identification System . 566
Worldwide Sales and Service . 568  2014-2019 Microchip Technology Inc. DS40001775E-page 8
