Datasheet PIC16(L)F153XX (Microchip)
Manufacturer | Microchip |
Description | Cost-Effective 8 to 48 Pins Microcontroller Product Brief |
Pages / Page | 24 / 1 — PIC16(L)F153XX. Cost-Effective 8 to 48 Pins Microcontroller Product … |
File Format / Size | PDF / 328 Kb |
PIC16(L)F153XX. Cost-Effective 8 to 48 Pins Microcontroller Product Brief. Description. Core Features
PIC16(L)F153XX Cost-Effective 8 to 48 Pins Microcontroller Product Brief Description
PIC16(L)F153XX microcontrollers feature Intelligent Analog, Core Independent Peripherals (CIPs) and communication peripherals combined with eXtreme Low-Power (XLP) for a wide range of general purpose and low-power applications. The family features PWMs, multiple communication, temperature sensor and memory features like Memory Access Partition (MAP) and Device Information Area (DIA). The products are offered in a broad range of pin counts from 8 to 48 pins, to support customers in various applications.
Core Features Power-Saving Functionality
• C Compiler Optimized RISC Architecture • Doze mode: • Only 49 Instructions - Ability to run CPU core slower than the • Operating Speed: system clock - DC – 32 MHz clock input • Idle mode: - 125 ns minimum instruction cycle - Ability to halt CPU core while internal • Interrupt Capability peripherals continue operating • 16-Level Deep Hardware Stack • Sleep mode: • Timers: - Lowest power consumption - 8-bit (TMR2) with Hardware Limit Timer • Peripheral Module Disable (PMD): (HLT) Extension - Ability to disable hardware module to minimize - 16-bit (TMR0/1) power consumption of unused peripherals • Low-Current Power-on Reset (POR) • Configurable Power-up Timer (PWRTE)
eXtreme Low-Power (XLP) Features
• Brown-out Reset (BOR) with Fast Recovery • Sleep mode: 50 nA @ 1.8V, typical • Low-Power BOR (LPBOR) Option • Watchdog Timer: 500 nA @ 1.8V, typical • Windowed Watchdog Timer (WWDT): • Secondary Oscillator: 500 nA @ 32 kHz - Variable prescaler selection • Operating Current: - Variable window size selection - 8 uA @ 32 kHz, 1.8V, typical - All sources configurable in hardware or software - 32 uA/MHz @ 1.8V, typical • Programmable Code Protection
Digital Peripherals Memory
• Four Configurable Logic Cel s (CLCs): • Up to 28 KB Flash Program Memory - Integrated combinational and sequential logic • Up to 2 KB Data SRAM Memory • Complementary Waveform Generator (CWG): • Direct, Indirect and Relative Addressing modes - Rising and Falling edge dead-band control • Memory Access Partition (MAP): - Full-bridge, half-bridge, 1-channel drive - Write protect - Multiple signal sources - Customizable Partition • Two Capture/Compare/PWM (CCP) modules • Device Information Area (DIA) • Four 10-bit PWMs • Numerically Controlled Oscil ator (NCO):
Operating Characteristics
- Generates true linear frequency control and increased frequency resolution • Operating Voltage Range: - Input Clock: 0 Hz < fNCO < 32 MHz - 1.8V to 3.6V (PIC16LF153XX) - Resolution: fNCO/220 - 2.3V to 5.5V (PIC16F153XX) • Peripheral Pin Select (PPS): • Temperature Range: - Enables pin mapping of digital I/O - Industrial: -40°C to 85°C - Extended: -40°C to 125°C 2016 Microchip Technology Inc.
Advance Information
DS40001835A-page 1 Document Outline Description Core Features Memory Operating Characteristics Power-Saving Functionality eXtreme Low-Power (XLP) Features Digital Peripherals Analog Peripherals Flexible Oscillator Structure TABLE 1: PIC16(L)F153XX Family Types TABLE 2: Packages Pin Diagrams FIGURE 1: 8-Pin PDIP, SOIC, MSOP, for PIC16(L)F15313 FIGURE 2: 14-Pin PDIP, SOIC, TSSOP for PIC16(L)F15323 FIGURE 3: 14-Pin PDIP, TSSOP for PIC16(L)F15324 and PIC16(L)F15325 FIGURE 4: 20-Pin PDIP, SOIC, SSOP for PIC16(L)F15344, PIC16(L)F15345 FIGURE 5: 28-Pin PDIP, SOIC, SSOP for PIC16(L)F15354, PIC16(L)F15355, PIC16(L)F15356 FIGURE 6: 40-Pin PDIP for PIC16(L)F15375, PIC16(L)F15376 FIGURE 7: 16-Pin QFN/UQFN (4x4) for PIC16(L)F15323, PIC16(L)F15324, PIC16(L)F15325 FIGURE 8: 20-Pin QFN/UQFN (4x4) for PIC16(L)F15344 and PIC16(L)F15345 FIGURE 9: 28-Pin UQFN (4x4) for PIC16(L)F15354, PIC16(L)F15355, PIC16(L)F15356 FIGURE 10: 28-Pin QFN (6x6) for PIC16(L)F15354, PIC16(L)F15355, PIC16(L)F15356 FIGURE 11: 40-Pin UQFN (5x5) for PIC16(L)F15375, PIC16(L)F15376 FIGURE 12: 44-Pin TQFP (10x10) for PIC16(L)F15375, PIC16(L)F15376 FIGURE 13: 44-Pin QFN (8x8x0.9) for PIC16(L)F15375, PIC16(L)F15376 FIGURE 14: 48-Pin UQFN (6x6) for PIC16(L)F15385, PIC16(L)F15386 FIGURE 15: 48-Pin TQFP (7x7) for PIC16(L)F15385, PIC16(L)F15386 Pin Allocation Tables TABLE 3: 8-Pin Allocation Table (PIC16(L)F15313) TABLE 4: 14/16/20-Pin Allocation Table (PIC16(L)F15323, PIC16(L)F15324, PIC16(L)F15325, PIC16(L)F15344, PIC16(L)F15345) TABLE 5: 28-Pin Allocation Table (PIC16(L)F15354, PIC16(L)F15355, PIC16(L)F15356) TABLE 6: 40/44-Pin Allocation Table (PIC16(L)F15375, PIC16(L)F15376) TABLE 7: 48-Pin Allocation Table (PIC16(L)F15385, PIC16(L)F15386) Trademarks Worldwide Sales
