Datasheet PIC16(L)F153XX (Microchip) - 2
Manufacturer | Microchip |
Description | Cost-Effective 8 to 48 Pins Microcontroller Product Brief |
Pages / Page | 24 / 2 — PIC16(L)F153XX. Analog Peripherals. Flexible Oscillator Structure. … |
File Format / Size | PDF / 328 Kb |
PIC16(L)F153XX. Analog Peripherals. Flexible Oscillator Structure. Advance Information
PIC16(L)F153XX
• Communication: - Up to two EUSART, RS-232, RS-485, LIN compatible - Up to two SPI - Two I2C, SMBus, PMBus™ compatible • Up to 44 I/O Pins - Individually programmable pull-ups slew rate control Interrupt-on-Change with edge-select
Analog Peripherals
• Analog-to-Digital Converter (ADC): - 10-bit with up to 43 external channels - Conversion available during Sleep • Two Comparator: - Low-Power/High-Speed mode - Fixed Voltage Reference at (non)inverting input(s) - Comparator outputs externally accessible • 5-Bit Digital-to-Analog Converter (DAC): - 5-bit resolution, rail-to-rail - Positive Reference Selection - Unbuffered I/O pin output - Internal connections to ADCs and comparators • Voltage Reference: - Fixed Voltage Reference with 1.024V, 2.048V and 4.096V output level
• High-Precision Internal Oscillator: - Selectable frequency range up to 32 MHz - ±1% at calibration (nominal) • x2/x4 PLL with Internal and External Sources • Low-Power Internal 32 kHz Oscillator (LFINTOSC) • External 32 kHz Crystal Oscil ator (SOCS) • External Oscillator Block with: - Three crystal/resonator modes up to 20 MHz - Three external clock modes up to 20 MHz - Fail-Safe Clock Monitor - Al ows for safe shutdown if peripherals clock stops - Oscillator Start-up Timer (OST) - Ensures stability of crystal oscillator sources DS40001835A-page 2
Advance Information
2016 Microchip Technology Inc. Document Outline Description Core Features Memory Operating Characteristics Power-Saving Functionality eXtreme Low-Power (XLP) Features Digital Peripherals Analog Peripherals Flexible Oscillator Structure TABLE 1: PIC16(L)F153XX Family Types TABLE 2: Packages Pin Diagrams FIGURE 1: 8-Pin PDIP, SOIC, MSOP, for PIC16(L)F15313 FIGURE 2: 14-Pin PDIP, SOIC, TSSOP for PIC16(L)F15323 FIGURE 3: 14-Pin PDIP, TSSOP for PIC16(L)F15324 and PIC16(L)F15325 FIGURE 4: 20-Pin PDIP, SOIC, SSOP for PIC16(L)F15344, PIC16(L)F15345 FIGURE 5: 28-Pin PDIP, SOIC, SSOP for PIC16(L)F15354, PIC16(L)F15355, PIC16(L)F15356 FIGURE 6: 40-Pin PDIP for PIC16(L)F15375, PIC16(L)F15376 FIGURE 7: 16-Pin QFN/UQFN (4x4) for PIC16(L)F15323, PIC16(L)F15324, PIC16(L)F15325 FIGURE 8: 20-Pin QFN/UQFN (4x4) for PIC16(L)F15344 and PIC16(L)F15345 FIGURE 9: 28-Pin UQFN (4x4) for PIC16(L)F15354, PIC16(L)F15355, PIC16(L)F15356 FIGURE 10: 28-Pin QFN (6x6) for PIC16(L)F15354, PIC16(L)F15355, PIC16(L)F15356 FIGURE 11: 40-Pin UQFN (5x5) for PIC16(L)F15375, PIC16(L)F15376 FIGURE 12: 44-Pin TQFP (10x10) for PIC16(L)F15375, PIC16(L)F15376 FIGURE 13: 44-Pin QFN (8x8x0.9) for PIC16(L)F15375, PIC16(L)F15376 FIGURE 14: 48-Pin UQFN (6x6) for PIC16(L)F15385, PIC16(L)F15386 FIGURE 15: 48-Pin TQFP (7x7) for PIC16(L)F15385, PIC16(L)F15386 Pin Allocation Tables TABLE 3: 8-Pin Allocation Table (PIC16(L)F15313) TABLE 4: 14/16/20-Pin Allocation Table (PIC16(L)F15323, PIC16(L)F15324, PIC16(L)F15325, PIC16(L)F15344, PIC16(L)F15345) TABLE 5: 28-Pin Allocation Table (PIC16(L)F15354, PIC16(L)F15355, PIC16(L)F15356) TABLE 6: 40/44-Pin Allocation Table (PIC16(L)F15375, PIC16(L)F15376) TABLE 7: 48-Pin Allocation Table (PIC16(L)F15385, PIC16(L)F15386) Trademarks Worldwide Sales
