Datasheet AOZ6682CI (Alpha & Omega)
ManufacturerAlpha & Omega
DescriptionEZBuck 2A Synchronous Buck Regulator
Pages / Page14 / 1 — AOZ6682CI. EZBuckTM 2A Synchronous Buck Regulator. General Description. …
File Format / SizePDF / 808 Kb
AOZ6682CI. EZBuckTM 2A Synchronous Buck Regulator. General Description. Features. Applications. Typical Application
Datasheet AOZ6682CI Alpha & Omega
AOZ6682CI EZBuckTM 2A Synchronous Buck Regulator General Description Features
The AOZ6682CI is a high efficiency, easy to use, 2A 4.5V to 18V operating input voltage range synchronous buck regulator at high switching frequency Synchronous Buck: 125mΩ internal high-side switch for small form factor solution. The AOZ6682CI works and 55mΩ internal low-side switch from 4.5V to 18V input voltage range, and provides up to Up to 95% efficiency 2A of continuous output current with an output voltage adjustable down to 0.8V. Pulse energy mode for high light load efficiency (Vin=12V, Vo=5V, 89% @10mA) The AOZ6682CI comes in an ultra thin TSOT23-6L Output voltage adjustable to 0.8V package and is rated from -40°C to +125°C junction 2A continuous output current temperature range. 750kHz PWM operation Internal compensation Internal Soft Start Cycle-by-cycle current limit Pre-bias start-up Short-circuit protection Thermal shutdown Ultra-thin TSOT23-6L package
Applications
General Point of Load LCD TV Cable modems and Gateway
Typical Application
VIN VIN BST 4.5V ~ 18V CIN CBST L1 V IN V IN B S T
AOZ6682CI
4 .5 V ~ 18 V LX VOUT C IN C BST L 1
A O Z 6 6 82C I
LX R1 V O U T EN EN RT E N FB E N GND R R T 1 F B C G N D O C O R R 2 2
Figure 1. 2A Synchronous Buck Regulator
Rev. 1.0 December 2018
www.aosmd.com
Page 1 of 14
