Datasheet AOZ6682CI (Alpha & Omega) - 2
ManufacturerAlpha & Omega
DescriptionEZBuck 2A Synchronous Buck Regulator
Pages / Page14 / 2 — AOZ6682CI. Ordering Information. Part Number. Ambient Temperature Range. …
File Format / SizePDF / 808 Kb
AOZ6682CI. Ordering Information. Part Number. Ambient Temperature Range. Package. Environmental. Pin Configuration. TSOT23. (Top View)
AOZ6682CI Ordering Information Part Number Ambient Temperature Range Package Environmental Pin Configuration TSOT23 (Top View)
AOZ6682CI -40°C to +125°C TSOT23-6L RoHS AOS Green Products use reduced levels of Halogens, and are also RoHS compliant. Please visit www.aosmd.com/media/AOSGreenPolicy.pdf for additional information.
Pin Configuration
GND 1 6 BST LX 2 5 EN VIN 3 4 FB
TSOT23 (Top View) Pin Description Pin Number Pin Name Pin Function
1 GND System ground. 2 LX Switching node connects to main inductor terminal. Supply voltage input. When VIN rises above the UVLO threshold and EN is logic high, the 3 VIN device will start up. Feedback input. The FB pin is used to set the output voltage through a resistor voltage 4 FB divider between the Output and GND. Enable input. Pull EN to logic high will enable the device. Pull EN to logic low will disable 5 EN the device. EN pin must be connected to VIN if no Enable control is required. 6 BST Bootstrap input. Connect a capacitor to LX (Pin 2). Typical value is 0.1uF. Rev. 1.0 December 2018
www.aosmd.com
Page 2 of 14
