Data Brief AP64352 (Diodes)
Manufacturer | Diodes |
Description | 3.8V To 40V, 3.5A Low Iq Synchronous Buck with Internal Compensation |
Pages / Page | 5 / 1 — Request Datasheet. AP64352. 3.8V TO 40V INPUT, 3.5A LOW IQ SYNCHRONOUS … |
File Format / Size | PDF / 429 Kb |
Request Datasheet. AP64352. 3.8V TO 40V INPUT, 3.5A LOW IQ SYNCHRONOUS BUCK WITH INTERNAL COMPENSATION. Description
Request Datasheet AP64352 3.8V TO 40V INPUT, 3.5A LOW IQ SYNCHRONOUS BUCK WITH INTERNAL COMPENSATION Description Pin Assignments
The AP64352 is a 3.5A, synchronous buck converter with a wide input voltage range of 3.8V to 40V. The device fully integrates a 75mΩ high-
TOP VIEW
side power MOSFET and a 45mΩ low-side power MOSFET to provide high-efficiency step-down DC-DC conversion.
BST 1 8 SW
The AP64352 device is easily used by minimizing the external component count due to its adoption of peak current mode control along with its integrated loop compensation network.
VIN 2 7 GND EXPOSED PAD
The AP64352 design is optimized for Electromagnetic Interference
9
(EMI) reduction. The device has a proprietary gate driver scheme to resist switching node ringing without sacrificing MOSFET turn-on and
EN 3 6 SS
turn-off times, which reduces high-frequency radiated EMI noise caused by MOSFET switching. AP64352 also features Frequency Spread Spectrum (FSS) with a switching frequency jitter of ±6%,
RT/CLK 4 5 FB
which reduces EMI by not allowing emitted energy to stay in any one frequency for a significant period of time.
SO-8EP
The device is available in an SO-8EP package.
Features Typical Application Circuit
VIN 3.8V to 40V
INPUT VIN BST
3.5A Continuous Output Current
C3 L 100nF OUTPUT
0.8V ± 1% Reference Voltage
5.5μH EN SW VOUT 5V
22µA Low Quiescent Current (Pulse Frequency Modulation)
C4 R1 OPEN 115kΩ C1 AP64352
Programmable Switching Frequency: 100kHz to 2.2MHz
FB C2 10µF 2 x 22µF R2
External Clock Synchronization: 100kHz to 2.2MHz
22.1kΩ
Programmable Soft-Start Time
RT/CLK SS RT Css
Up to 85% Efficiency at 5mA Light Load
200kΩ GND 10nF
Proprietary Gate Driver Design for Best EMI Reduction Frequency Spread Spectrum (FSS) to Reduce EMI Low-Dropout (LDO) Mode Precision Enable Threshold to Adjust UVLO VOUT = 5V, L = 5.5μH VOUT = 3.3V, L = 4.7μH Protection Circuitry o Undervoltage Lockout (UVLO) 100 o Output Overvoltage Protection (OVP) 90 o 80 Cycle-by-Cycle Peak Current Limit
70 o Thermal Shutdown
60
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2) ncy
50
Halogen and Antimony Free. “Green” Device (Note 3) eic
40
if f
30
E
20 10 0 0.001 0.010 0.100 1.000 10.000
IOUT (A)
Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and\ Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 1 of 5 AP64352 Databrief October 2019
www.diodes.com
© Diodes Incorporated
