User Manual WSEN-PADS / 2511020213301 (Wurth Elektronik) - 5
ManufacturerWurth Elektronik
DescriptionAbsolute Pressure Sensor
Pages / Page87 / 5 — Modes of operation. Reading output data. FIFO buffer. 10 Interrupt …
File Format / SizePDF / 9.2 Mb
Modes of operation. Reading output data. FIFO buffer. 10 Interrupt functionality. 11 Register map. 12 Register description
Modes of operation Reading output data FIFO buffer 10 Interrupt functionality 11 Register map 12 Register description
link to page 30 link to page 31 link to page 32 link to page 33 link to page 34 link to page 34 link to page 35 link to page 36 link to page 36 link to page 37 link to page 38 link to page 39 link to page 41 link to page 42 link to page 43 link to page 44 link to page 45 link to page 46 link to page 47 link to page 48 link to page 48 link to page 49 link to page 49 link to page 50 link to page 52 link to page 53 link to page 53 link to page 14 link to page 55 link to page 56 link to page 56 link to page 58 link to page 58 link to page 59 link to page 59 link to page 60 link to page 61 link to page 62 link to page 63 link to page 64 link to page 64 link to page 64 link to page 65 link to page 65 link to page 66 link to page 66
7 Modes of operation 29
7.1 Power-down mode . 30 7.2 Single conversion mode . 31 7.3 Continuous mode . 32 7.4 Additional configurations . 33 7.4.1 Low-power or low-noise configuration . 33 7.4.2 Enabling additional low-pass filter . 34
8 Reading output data 35
8.1 Reading pressure values . 35 8.2 Reading temperature values . 36 8.3 Status register for reading the data . 37
9 FIFO buffer 38
9.1 Bypass mode . 40 9.2 FIFO mode . 41 9.3 Continuous mode . 42 9.4 Bypass-to-FIFO mode . 43 9.5 Bypass-to-continuous mode . 44 9.6 Continuous-to-FIFO mode . 45 9.7 FIFO status monitoring and control . 46 9.7.1 User-defined FIFO threshold . 47 9.7.2 Reading data from FIFO buffer . 47
10 Interrupt functionality 48
10.1 Interrupt generation on pressure data-ready . 48 10.2 Interrupt generation based on pressure threshold . 49 10.2.1 Interrupt latching . 51 10.3 FIFO status based interrupt events . 52 10.4 Routing interrupt events to the INT pin . 52
11 Register map 54 12 Register description 55
12.1 INT_CFG (0x0B) . 55 12.2 THR_P_L (0x0C) . 57 12.3 THR_P_H (0x0D) . 57 12.4 INTERFACE_CTRL (0x0E) . 58 12.5 DEVICE_ID (0x0F) . 58 12.6 CTRL_1 (0x10) . 59 12.7 CTRL_2 (0x11) . 60 12.8 CTRL_3 (0x12) . 61 12.9 FIFO_CTRL (0x13) . 62 12.10 FIFO_WTM (0x14) . 63 12.11 REF_P_L (0x15) . 63 12.12 REF_P_H (0x16) . 63 12.13 OPC_L (0x18) . 64 12.14 OPC_H (0x19) . 64 12.15 INT_SOURCE (0x24) . 65 12.16 FIFO_STATUS_1 (0x25) . 65 Absolute pressure sensor, Part Nr. 2511020213301 User manual version 1.0 © June 2019 www.we-online.com/sensors 4 Document Outline Introduction Application Key features Ordering information Block diagram Operational functionality MEMS Cell ASIC Calibration Digital filtering FIFO memory Filtering chain and data path Sensor specifications General information Absolute maximum ratings Pressure sensor specification Temperature sensor specification Electrical specifications Pinning information Pin configuration Pin description Digital interface General characteristics [fig:pinout]SDA and [fig:pinout]SCL logic levels Communication phase Idle state START(S) and STOP(P) condition Data validity Byte format Acknowledge(ACK) and No-Acknowledge(NACK) Slave address for the sensor Read/Write operation I2C timing parameters Application circuit Quick start guide Power-up sequence Communication with host controller Reboot Software reset Sensor operation: single conversion mode Sensor operation: continuous mode Power-off sequence Modes of operation Power-down mode Single conversion mode Continuous mode Additional configurations Low-power or low-noise configuration Enabling additional low-pass filter Reading output data Reading pressure values Reading temperature values Status register for reading the data FIFO buffer Bypass mode FIFO mode Continuous mode Bypass-to-FIFO mode Bypass-to-continuous mode Continuous-to-FIFO mode FIFO status monitoring and control User-defined FIFO threshold Reading data from FIFO buffer Interrupt functionality Interrupt generation on pressure data-ready Interrupt generation based on pressure threshold Interrupt latching FIFO status based interrupt events Routing interrupt events to the [fig:pinout]INT pin Register map Register description INT_CFG (0x0B) THR_P_L (0x0C) THR_P_H (0x0D) INTERFACE_CTRL (0x0E) DEVICE_ID (0x0F) CTRL_1 (0x10) CTRL_2 (0x11) CTRL_3 (0x12) FIFO_CTRL (0x13) FIFO_WTM (0x14) REF_P_L (0x15) REF_P_H (0x16) OPC_L (0x18) OPC_H (0x19) INT_SOURCE (0x24) FIFO_STATUS_1 (0x25) FIFO_STATUS_2 (0x26) STATUS (0x27) DATA_P_XL (0x28) DATA_P_L (0x29) DATA_P_H (0x2A) DATA_T_L (0x2B) DATA_T_H (0x2C) FIFO_DATA_P_XL (0x78) FIFO_DATA_P_L (0x79) FIFO_DATA_P_H (0x7A) FIFO_DATA_T_L (0x7B) FIFO_DATA_T_H (0x7A) Physical dimensions Sensor drawing Footprint Manufacturing information Moisture sensitivity level Soldering Reflow soldering Cleaning and washing Potting and coating Storage conditions Handling Important notes General customer responsibility Customer responsibility related to specific, in particular safety-relevant applications Best care and attention Customer support for product specifications Product improvements Product life cycle Property rights General terms and conditions Legal notice Exclusion of liability Suitability in customer applications Usage restriction License agreement for Würth Elektronik eiSos GmbH & Co. KG sensor product software and source code Limited license Usage and obligations Ownership Disclaimer of warranty Limitation of liability Applicable law and jurisdiction Severability clause Miscellaneous
