Datasheet UBY (Nichicon) - 2
ManufacturerNichicon
DescriptionAluminum Electrolytic Capacitors High Temperature Range, For +125°C or 135°C Use
Pages / Page3 / 2 — ALUMINUM ELECTROLYTIC CAPACITORS. UBY. 25(1E). 35(1V). 1300. 1800. 2000. …
File Format / SizePDF / 717 Kb
ALUMINUM ELECTROLYTIC CAPACITORS. UBY. 25(1E). 35(1V). 1300. 1800. 2000. 2200. 2700. 3000. 3300. 3600. 3900. 4300. 4700. 5100. 5600. 6200. 7500. 8200. 9100
ALUMINUM ELECTROLYTIC CAPACITORS UBY 25(1E) 35(1V) 1300 1800 2000 2200 2700 3000 3300 3600 3900 4300 4700 5100 5600 6200 7500 8200 9100
UBY
Dimensions V (Code)
25(1E) 35(1V)
Case size ESR(Ω) MAX. Rated ripple (mArms) Case size ESR(Ω) MAX. Rated ripple (mArms) Item φD × L φD × L (mm) 135℃ (mm) 20℃/100kHz −40℃/100kHz 125℃ 135℃ Cap.(µF) /100kHz /100kHz 20℃/100kHz −40℃/100kHz 125℃ /100kHz /100kHz Code
1300
132 12.5 × 20 0.042 0.48 2760 1690
1800
182 12.5 × 25 0.033 0.30 3480 2010
2000
202 12.5 × 20 0.042 0.48 2760 1690 12.5 × 31.5 0.028 0.24 4490 2900
2200
222 ▲16 × 20 0.031 0.27 3040 1860 12.5 × 35.5 0.025 0.21 5140 3190
2700
272 ▲18 × 20 0.030 0.22 3250 1870
3000
302 12.5 × 25 0.033 0.30 3480 2010 16 × 25 0.026 0.22 4260 2870
3300
332 16 × 20 0.031 0.27 3040 1860 12.5 × 40 0.024 0.19 5810 3470
3600
362 12.5 × 31.5 0.028 0.24 4490 2900 16 × 31.5 0.023 0.18 5480 3400
3900
392 ▲18 × 25 0.025 0.19 4500 2900
4300
432 18 × 20 0.030 0.22 3250 1870
4700
472 16 × 25 0.026 0.22 4260 2870 16 × 35.5 0.020 0.14 6070 3630
5100
512 12.5 × 40 0.024 0.19 5810 3470 18 × 31.5 0.022 0.16 5600 3470
5600
562 16 × 40 0.019 0.12 6810 3930 16 × 31.5 0.023 0.18 5480 3400 18 × 35.5 0.019 0.12 6280 3750
6200
622 ▲18 × 25 0.025 0.19 4500 2900
7500
752 16 × 35.5 0.020 0.14 6070 3630 18 × 40 0.018 0.10 7070 4080
8200
822 18 × 31.5 0.022 0.16 5600 3470
9100
912 16 × 40 0.019 0.12 6810 3930
10000
103 18 × 35.5 0.019 0.12 6280 3750
12000
123 18 × 40 0.018 0.10 7070 4080 V (Code)
50 (1H) 63 (1J)
390
391 12.5 × 20 0.074 0.56 1640 1420
560
561 12.5 × 25 0.054 0.39 2520 2050
620
621 12.5 × 20 0.056 0.52 2400 1470 12.5 × 31.5 0.042 0.30 3110 2630
750
751 ▲16 × 20 0.053 0.34 2140 1910
820
821 12.5 × 25 0.044 0.35 3350 2260 12.5 × 35.5 0.038 0.25 3760 2970
950
951 ▲18 × 20 0.048 0.26 2350 2100
1000
102 16 × 20 0.039 0.30 2960 1870 16 × 25 0.038 0.23 2940 2680
1100
112 12.5 × 31.5 0.037 0.26 4220 2520 12.5 × 40 0.031 0.22 4610 3260 12.5 × 35.5 0.033 0.23 4810 2780 16 × 31.5 0.034 0.20 3860 3050
1300
132 ▲16 × 25 0.033 0.22 4040 2500 ▲18 × 25 0.035 0.19 3080 2810 ※18 × 20 0.038 0.20 3130 2110
1600
162 12.5 × 40 0.032 0.20 5240 3020
1700
172 16 × 35.5 0.027 0.15 4590 3420 16 × 31.5 0.029 0.19 5130 2960 18 × 31.5 0.028 0.15 4080 3220
1800
182 ▲18 × 25 0.032 0.19 4230 2530
2000
202 16 × 40 0.025 0.14 5190 3670
2200
222 16 × 35.5 0.025 0.14 5480 3160 18 × 35.5 0.023 0.12 5220 3690
2400
242 18 × 31.5 0.025 0.16 5240 3020
2500
252 18 × 40 0.021 0.11 5660 3820
2700
272 16 × 40 0.022 0.13 5930 3420
3000
302 18 × 35.5 0.022 0.12 5870 3390
3600
362 18 × 40 0.020 0.10 6420 3700 : In this case, 6 will be put at 12th digit of type numbering system. : In this case, 3 will be put at 12th digit of type numbering system. ※ 272
