Datasheet UBY (Nichicon) - 3
Manufacturer | Nichicon |
Description | Aluminum Electrolytic Capacitors High Temperature Range, For +125°C or 135°C Use |
Pages / Page | 3 / 3 — ALUMINUM ELECTROLYTIC CAPACITORS UBY. 80 (1K). 100 (2A). 160. 220. 270. … |
File Format / Size | PDF / 717 Kb |
ALUMINUM ELECTROLYTIC CAPACITORS UBY. 80 (1K). 100 (2A). 160. 220. 270. 300. 360. 390. 430. 470. 510. 560. 620. 680. 750. 820. 950. 1000. 1100. 1300. 1600
Dimensions V (Code)
80 (1K) 100 (2A)
Case size ESR(Ω) MAX. Rated ripple (mArms) Case size ESR(Ω) MAX. Rated ripple (mArms) Item φD × L φD × L (mm) 135℃ (mm) 20℃/100kHz −40℃/100kHz 125℃ 135℃ Cap.(µF) /100kHz /100kHz 20℃/100kHz −40℃/100kHz 125℃ /100kHz /100kHz Code
160
161 12.5 × 20 0.074 0.56 1640 1420
220
221 12.5 × 25 0.054 0.39 2520 2050
270
271 12.5 × 20 0.074 0.56 1640 1420 16 × 20 0.053 0.34 2140 1910
300
301 12.5 × 31.5 0.042 0.30 3110 2630 12.5 × 35.5 0.038 0.25 3760 2970
360
361 ▲18 × 20 0.048 0.26 2350 2100
390
391 12.5 × 25 0.054 0.39 2520 2050 16 × 25 0.038 0.23 2940 2680
430
431 12.5 × 40 0.031 0.22 4610 3260
470
471 16 × 20 0.053 0.34 2140 1910 16 × 31.5 0.034 0.20 3860 3050
510
511 12.5 × 31.5 0.042 0.30 3110 2630 18 × 25 0.035 0.19 3080 2810
560
561 16 × 35.5 0.027 0.15 4590 3420 12.5 × 35.5 0.038 0.25 3760 2970
620
621 ▲18 × 20 0.048 0.26 2350 2100
680
681 16 × 25 0.038 0.23 2940 2680 18 × 31.5 0.028 0.15 4080 3220
750
751 12.5 × 40 0.031 0.22 4610 3260 16 × 40 0.025 0.14 5190 3670 16 × 31.5 0.034 0.20 3860 3050 18 × 35.5 0.023 0.12 5220 3690
820
821 ▲18 × 25 0.035 0.19 3080 2810
950
951 18 × 40 0.021 0.11 5660 3820
1000
102 16 × 35.5 0.027 0.15 4590 3420
1100
112 18 × 31.5 0.028 0.15 4080 3220 16 × 40 0.025 0.14 5190 3670
1300
132 ▲18 × 35.5 0.023 0.12 5220 3690
1600
162 18 × 40 0.021 0.11 5660 3820 : In this case, 6 will be put at 12th digit of type numbering system. Frequency coefficient of rated ripple current Frequency 120Hz 1kHz 10kHz 100kHz or more Cap. (µF) 160 0.40 0.75 0.90 1.00 220 to 620 0.50 0.85 0.94 1.00 680 to 2000 0.60 0.87 0.95 1.00 2200 to 4300 0.75 0.90 0.95 1.00 4700 to 12000 0.85 0.95 0.98 1.00 273
