Datasheet TCA0372, TCA0372B, NCV0372B (ON Semiconductor) - 3
ManufacturerON Semiconductor
Description1.0 A Output Current, Dual Power Operational Amplifiers
Pages / Page10 / 3 — TCA0372, TCA0372B, NCV0372B. DC ELECTRICAL CHARACTERISTICS. …
File Format / SizePDF / 187 Kb
TCA0372, TCA0372B, NCV0372B. DC ELECTRICAL CHARACTERISTICS. Characteristics. Symbol. Min. Typ. Max. Unit. AC ELECTRICAL CHARACTERISTICS
TCA0372, TCA0372B, NCV0372B DC ELECTRICAL CHARACTERISTICS Characteristics Symbol Min Typ Max Unit AC ELECTRICAL CHARACTERISTICS
(VCC = +15 V, VEE = −15 V, RL connected to ground, TA = −40° to +125°C.)
Input Offset Voltage (VCM = 0) VIO mV TA = +25°C − 1.0 15 TA, Tlow to Thigh − − 20 Average Temperature Coefficient of Offset Voltage DVIO/DT − 20 − mV/°C Input Bias Current (VCM = 0) IIB − 100 500 nA Input Offset Current (VCM = 0) IIO − 10 50 nA Large Signal Voltage Gain AVOL 30 100 − V/mV VO = ±10 V, RL = 2.0 k Output Voltage Swing (IL = 100 mA) VOH V TA = +25°C 14.0 14.2 − TA = Tlow to Thigh 13.9 − − TA = +25°C VOL − −14.2 −14.0 TA = Tlow to Thigh − − −13.9 Output Voltage Swing (IL = 1.0 A) VOH V VCC = +24 V, VEE = 0 V, TA = +25°C 22.5 22.7 − VCC = +24 V, VEE = 0 V, TA = Tlow to Thigh 22.5 − − VCC = +24 V, VEE = 0 V, TA = +25°C VOL − 1.3 1.5 VCC = +24 V, VEE = 0 V, TA = Tlow to Thigh − − 1.6 Input Common Mode Voltage Range VICR V TA = +25°C VEE to (VCC −1.0) TA = Tlow to Thigh VEE to (VCC −1.3) Common Mode Rejection Ratio (RS = 10 k) CMRR 70 90 − dB Power Supply Rejection Ratio (RS = 100 W) PSRR 70 90 − dB Power Supply Current ID mA TA = +25°C TCA0372 − 5.0 10 TCA0372B/NCV0372B − 8.0 10 TA = Tlow to Thigh TCA0372 − − 14 TCA0372B/NCV0372B − − 14
(VCC = +15 V, VEE = −15 V, RL connected to ground, TA = +25°C, unless otherwise noted.)
Slew Rate (Vin = −10 V to +10 V, RL = 2.0 k, CL = 100 pF) SR 1.0 1.4 − V/ms AV = −1.0, TA = Tlow to Thigh Gain Bandwidth Product (f = 100 kHz, CL = 100 pF, RL = 2.0 k) GBW MHz TA = 25°C 0.9 1.4 − TA = Tlow to Thigh 0.7 − − Phase Margin TJ = Tlow to Thigh fm − 65 − Degrees RL = 2.0 k, CL = 100 pF Gain Margin Am − 15 − dB RL = 2.0 k, CL = 100 pF Equivalent Input Noise Voltage en − 22 − nV/√Hz RS = 100 W, f = 1.0 to 100 kHz Total Harmonic Distortion THD − 0.02 − % AV = −1.0, RL = 50 W, VO = 0.5 VRMS, f = 1.0 kHz NOTE
In case VEE is disconnected before VCC, a diode between VEE and Ground is recommended to avoid damaging the device.
http://onsemi.com 3
