Datasheet MAX517, MAX518, MAX519 (Maxim) - 5
Manufacturer | Maxim |
Description | 2-Wire, Serial, 8-Bit DACs with Rail-to-Rail Outputs |
Pages / Page | 16 / 5 — 2-Wire Serial 8-Bit DACs with. Rail-to-Rail Outputs. MAX517/MAX518/MAX519 |
File Format / Size | PDF / 1.2 Mb |
2-Wire Serial 8-Bit DACs with Rail-to-Rail Outputs MAX517/MAX518/MAX519 __________________________________________Typical Operating Characteristics
(TA = +25°C, unless otherwise noted.)
FULL-SCALE ERROR vs. SOURCE CURRENT ZERO-CODE ERROR MAX517/MAX519 SUPPLY CURRENT (VREF = VDD) vs. SINK CURRENT vs. TEMPERATURE
10 10 3.0 VDD = VREF = 5V VDD = VREF = 5V VDD = 5.5V DAC CODE = FF HEX MAX517-01 DAC CODE = 00 HEX MAX517-02 REF_ INPUTS = 0.6V MAX517-03 LOAD TO AGND 2.5 ALL DIGITAL INPUTS to V 8 8 LOAD to VDD DD 2.0 6 6 MAX519, DAC CODE = FF HEX 1.5 4 4 1.0 MAX517, DAC CODE = FF HEX FULL-SCALE ERROR (LSB) ZERO-CODE ERROR (LSB) SUPPLY CURRENT (mA) 2 2 0.5 MAX517, MAX519 DAC CODE = 00 HEX 0 0 0 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 0 0.5 1.0 1.5 2.0 -55 -35 -15 5 25 45 65 85 105 125 OUTPUT SOURCE CURRENT (mA) OUTPUT SINK CURRENT (mA) TEMPERATURE (°C)
MAX518 SUPPLY CURRENT MAX518 SUPPLY CURRENT SHUTDOWN SUPPLY CURRENT vs. TEMPERATURE vs. DAC CODE vs. TEMPERATURE
3.5 3.0 6 VDD = 5.5V VDD = 5.5V VDD = 5.5V 3.0 MAX517-04 AD0, AD1 = VDD BOTH DACS SET MAX517-05 ALL DIGITAL INPUTS to V MAX517-07 2.5 µA) DD 5 2.5 DAC CODE = 1B HEX 2.0 4 2.0 1.5 3 1.5 DAC CODE = FF HEX 1.0 2 1.0 SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) 0.5 1 0.5 DAC CODE = 00 HEX SHUTDOWN SUPPLY CURRENT ( 0 0 0 -55 -35 -15 5 25 45 65 85 105 125 0 32 64 96 128 160 192 224 256 -55 -35 -15 5 25 45 65 85 105 125 TEMPERATURE (°C) DAC CODE (DECIMAL) TEMPERATURE (°C)
MAX517/MAX519 SUPPLY CURRENT MAX517/MAX519 REFERENCE VOLTAGE INPUT POSITIVE FULL-SCALE STEP RESPONSE vs. REFERENCE VOLTAGE FREQUENCY RESPONSE
2.5 VDD = 5V 0 MAX517-08 DAC CODE(S) FF HEX MAX517-09 2.0 -4 1.5 MAX519 OUT0 4V -8 P-P SINE 1V/div 2VP-P SINE 1.0 1VP-P SINE MAX517 0.5VP-P SINE -12 SUPPLY CURRENT (mA) RELATIVE OUTPUT (dB) 0.5 VDD = 5V -16 VREF = SINE WAVE CENTERED AT 2.5V 0 1µs/div 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 1k 10k 100k 1M 10M OUT0 LOADED WITH 10kΩ II 100pF REFERENCE VOLTAGE (V) FREQUENCY (Hz) REF0 = 4V (MAX517/MAX519) DAC CODE = 00 HEX to FF HEX
_______________________________________________________________________________________ 5
