Datasheet SIC466, SiC467, SiC468, SiC469 (Vishay) - 4
ManufacturerVishay
Description4.5 V to 60 V Input, 2 A, 4 A, 6 A, 10 A microBUCK DC/DC Converter
Pages / Page24 / 4 — SiC466, SiC467, SiC468, SiC469. RECOMMENDED OPERATING CONDITIONS. …
File Format / SizePDF / 955 Kb
SiC466, SiC467, SiC468, SiC469. RECOMMENDED OPERATING CONDITIONS. PARAMETER MIN. TYP. MAX. UNIT. Temperature. Note
SiC466, SiC467, SiC468, SiC469 RECOMMENDED OPERATING CONDITIONS PARAMETER MIN TYP MAX UNIT Temperature Note
(all voltages referenced to GND = 0 V)
Input voltage (VIN) 4.5 - 60 Control input voltage (VCIN) (1) 4.5 - 60 Enable (EN) 0 - 60 V Bias supply (VDD) 4.75 5 5.25 Drive supply voltage (VDRV) 4.75 5.3 5.55 Output voltage (VOUT) 0.8 - 24
Temperature
Recommended ambient temperature -40 to +105 °C Operating junction temperature -40 to +125
Note
(1) For input voltages below 5 V, provide a separate supply to VCIN of at least 5 V to prevent the internal VDD rail UVLO from triggering
ELECTRICAL SPECIFICATIONS
(VIN = VCIN = 48 V, TJ = -40 °C to +125 °C, unless otherwise stated)
PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Power Supplies
VIN = VCIN = 6 V to 60 V, 4.55 5 5.3 VEN = 5 V, not switching VDD supply VDD V VIN = VCIN = 5 V, 4.5 5 - VEN = 5 V, not switching VDD dropout VDD_DROPOUT VIN = VCIN = 5 V, IVDD = 1 mA - 150 - mV VDD UVLO threshold, rising VDD_UVLO 3.75 4 4.25 V VDD UVLO hysteresis VDD_UVLO_HYST - 150 - mV Input current IVCIN Non-switching, VFB > 0.8 V - 156 200 μA Shutdown current IVCIN_SHDN VEN = 0 V - 4 8
Controller and Timing
TJ = 25 °C 796 800 804 Feedback voltage VFB m/V TJ = -40 °C to +125 °C (1) 792 800 808 VFB input bias current IFB - 2 - nA Minimum on-time tON_MIN. - 45 100 ns tON accuracy tON_ACCURACY -10 - 10 % On-time range tON_RANGE 100 - 8000 ns Minimum off-time tOFF_MIN. - 250 - ns Soft start current ISS 2 5 7 μA Zero crossing detection point ZCD LX-PGND -3 - 3 mV S19-0911-Rev. E, 28-Oct-2019
4
Document Number: 76044 For technical questions, contact: powerictechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
