Datasheet TCPP01-M12 (STMicroelectronics) - 4
DescriptionUSB type-C port protection
Pages / Page25 / 4 — TCPP01-M12. Characteristics. Table 2. Absolute maximum ratings (Tamb = …
File Format / SizePDF / 2.5 Mb
TCPP01-M12. Characteristics. Table 2. Absolute maximum ratings (Tamb = 25°C). Value. Symbol. Parameter. Pin name. Unit. Min. Max
TCPP01-M12 Characteristics Table 2 Absolute maximum ratings (Tamb = 25°C) Value Symbol Parameter Pin name Unit Min Max
link to page 4 link to page 10 link to page 10
TCPP01-M12 Characteristics 3 Characteristics Table 2. Absolute maximum ratings (Tamb = 25°C) Value Symbol Parameter Pin name Unit Min. Max.
VCC -0.3 4 VDC VPOWER Voltage for Power pins IN_GD -0.3 22 VDC VIN Voltage for Input pins VBUS_CTRL, DB/, CC1, CC2 -0.3 4 VDC FLT/, SOURCE -0.3 5.5 VDC VOUT Voltage for Output pins GATE -0.3 27 VDC VI/O Voltage for CC1c, CC2c pins CC1c, CC2c -0.6 22 VDC Rthj-a Junction-to-ambient thermal resistance 150 °C/W TJ Junction temperature -40 +85 °C TSTG Storage temperature range -55 +150 °C
Table 3. ESD ratings (Tamb = 25°C) Symbol Description Pins Value Unit
System level ESD robustness on USB type-C connector side VESD_c IEC61000-4-2 Level 4, air discharge 15 kV SOURCE, CC1c, CC2c, VBUS_CTRL(1) IEC61000-4-2 Level 4, contact discharge 8 VHBM VESD ratings Human body model (JESD22-A114D, level 2) 2 kV 1. VBUS_CTRL ESD capability is guaranteed by the external resistor R1min = 3.8 kΩ (see Figure 16. Sink applications, without battery, PPS compliant). Note: for more information on IEC61000-4-2 standard testing, please refer to AN3353.
Table 4. Electrical characteristics – Power supply and leakage current, Tamb = -40 °C to +85 °C Value Symbol Parameter Test condition Unit Min. Typ. Max.
VCC Allowable voltage input range - 3.0 3.3 3.6 V IVCC Vcc supply current 120 µA VBUS Allowable voltage range VCC = 3.0 - 3.6 V 3.3 22 V IL_VBUS VBUS Supply current at VBUS = 22 V 2 mA
DS12900
Rev 1 page 4/25
Document Outline Cover image Product status / summary Features Applications Description 1 Pinout and functions 2 TCPP01-M12 simplified internal block diagram 3 Characteristics 4 Typical electrical characteristics curves 5 Application 5.1 General information 5.2 Electrical hazards related to USB Type-C 5.2.1 CC lines short to VBUS 5.2.2 Defective charger 5.2.3 Electrostatic discharge (ESD) 5.3 USB Type-C protection 5.4 USB charging system scalability 5.5 How to handle dead battery (DB) condition with the TCPP01-M12 5.6 Application example for USB type-C power delivery for sink (consumer), PPS compliant, without battery 5.6.1 ESD capacitor (C3) 5.6.2 CC line capacitance (C1, C2) 5.6.3 Sense resistor (R1, R2) 5.6.4 N-channel MOSFET (T1) 5.6.5 Complementary products for USB dataline protection for pins DP, DM, SSRX, SSTX 5.7 Typical USB-C battery powered application 5.8 Typical USB-C source application 5.9 Sink-source application example based on STM32G0 (with two UCPD ports) 6 PCB design recommendations 7 Package information 7.1 QFN12 package information 8 Ordering information Revision history
