link to page 29 link to page 21 link to page 29 EVALUATION KIT AVAILABLE Click here for production status of specific part numbers. MAX22700D–MAX22702DUltra-High CMTIMAX22700E–MAX22702EIsolated Gate DriversGeneral DescriptionBenefits and Features The MAX22700–MAX22702 are a family of single-chan- ● Matching Propagation Delay nel isolated gate drivers with ultra-high common-mode • 20ns Minimum Pulse Width transient immunity (CMTI) of 300kV/µs (typ). The devices • 35ns Propagation Delay at Room Temperature are designed to drive silicon-carbide (SiC) or gallium- • 2ns Part-to-Part Propagation Delay Matching at nitride (GaN) transistors in various inverter or motor Room Temperature control applications. All devices have integrated digital • 5ns Part-to-Part Propagation Delay Matching over galvanic isolation using Maxim’s proprietary process tech- -40°C to +125°C Temperature Range nology. The devices feature variants with output options ● High CMTI (300kV/µs, typ) for gate driver common pin GNDB (MAX22700), Miller ● Robust Galvanic Isolation clamp (MAX22701), and adjustable undervoltage-lockout • Withstands 3kVRMS for 60s (VISO) UVLO (MAX22702). In addition, variants are offered as • Continuously Withstands 848VRMS (VIOWM) differential (D versions) or single-ended (E versions) • Withstands ±5kV Surge Between GNDA and VSSB inputs. These devices transfer digital signals between with 1.2/50μs Waveform circuits with different power domains. All of the devices in ● Precision UVLO the family feature isolation for a withstand voltage rating of 3kVRMS for 60 seconds. ● Options to Support a Broad Range of Applications • 3 Output Options: GNDB, Miller Clamp, or All devices support a minimum pulse width of 20ns with a Adjustable UVLO maximum pulse width distortion of 2ns. The part-to-part • 2 Input Configurations: Single-Ended with Enable propagation delay is matched within 2ns (max) at +25°C (E versions) or Differential (D versions) ambient temperature, and 5ns (max) over the -40°C to +125°C operating temperature range. This feature Applications reduces the power transistor’s dead time, thus improving ● Isolated Gate Driver for Inverters overall efficiency. ● Motor Drives The MAX22700 and the MAX22702 have a maximum R ● UPS and PV Inverters DSON of 1.25Ω for the low-side driver, and the MAX22701 has an RDSON of 2.5Ω for the low-side driver. All devices Safety Regulatory Approvals have a maximum RDSON of 4.5Ω for the high-side driver. See the Ordering Information for suffixes associated with ● UL According to UL1577 each option. ● cUL According to CSA Bulletin 5A The MAX22700–MAX22702 can be used to drive SiC or GaN FETs with different output gate drive circuitry and B-side supply voltages. See the Typical Operating Circuits Ordering Informationappears at end of data sheet. for details. All of the devices in the MAX22700–MAX22702 family are available in an 8-pin, narrow-body SOIC package with 4mm of creepage and clearance. The package material has a minimum comparative tracking index (CTI) of 600V, which gives it a group I rat ing in creepage tables. All devices are rated for operation at ambient temperatures of -40°C to +125°C. 19-100581; Rev 2; 9/19
