Datasheet STPMIC1 (STMicroelectronics) - 9
Manufacturer | STMicroelectronics |
Description | Highly integrated power management IC for micro processor units |
Pages / Page | 141 / 9 — STPMIC1. Electrical and timing parameters. 3.4. Table 7. Electrical and … |
File Format / Size | PDF / 8.7 Mb |
STPMIC1. Electrical and timing parameters. 3.4. Table 7. Electrical and timing parameters. Symbol. Parameter. Test conditions. Min. Typ
link to page 120 link to page 120 link to page 82 link to page 82
STPMIC1 Electrical and timing parameters 3.4 Electrical and timing parameters Table 7. Electrical and timing parameters Symbol Parameter Test conditions Min. Typ. Max. Unit General section VIN = 3.6 V, VOUT1 = 1.2 V, VOUT2 = 1.2 V, VOUT3 = 1.8 V, VOUT4 = 3.3 V, VLDO1OUT/VLDO3OUT = 1.8 V, VLDO2OUT/VLDO5OUT/VLDO6OUT = 2.9 V, VIO = 1.8 V, recommended BOM, Tj = -40 °C to +125 °C, unless otherwise specified.
VIN Input voltage range 2.8 3.6 5.5 V V VIN POR rising IN_POR_Rise 2.2 2.3 2.4 V threshold V VIN POR falling IN_POR_Fall 2 2.1 2.2 V threshold 3 3.1 3.2 3.2 3.3 3.4 V VINOK rising Programmable value, defined in NVM register INOK_Rise V threshold Table 65. NVM_MAIN_CTRL_SHR 3.4 3.5 3.6 3.9 4 4.1 200 300 V Programmable value, defined in NVM register INOK_HYST VINOK hysteresis mV Table 65. NVM_MAIN_CTRL_SHR 400 500 Defined indirectly by V V V VINOK falling INOK_Rise and INOK_Rise - INOK_Fall threshold VINOK_HYST settings VINOK_HYST V +30 INOK_Fall +50 +80 V VINLOW rising Programmable value, defined in register INLOW_Rise mV threshold Table 30. SW_VIN_CR to +300 +500 VINOK_Fall +400 90 100 110 180 200 220 V Programmable value, defined in register INLOW_HYST VINLOW hysteresis mV Table 30. SW_VIN_CR 270 300 330 360 400 440 VINLOW_Rise Defined indirectly by V V VINLOW falling INLOW_Rise and INLOW_Fall mV threshold V + INLOW_HYST settings VINLOW_HYST T Warning WRN_Rise 115 125 140 °C temperature rising T Warning WRN_Fall 95 105 120 °C temperature falling T Shutdown SHDN_Rise 140 150 160 °C temperature rising T Shutdown SHDN_Fall 115 125 135 °C temperature falling t LDO OCP turn-off OCPDB_LDO 30 ms delay t BUCK OCP turn-off OCPDB_BUCK 5 µs delay t BOOST OVP turn- OVPDB_BST 1 ms off delay
DS12792
Rev 2 page 9/141
Document Outline Features Applications Description 1 Device configuration table 2 Typical application schematic 2.1 Recommended external components 2.2 Pinout and pin description 3 Electrical and timing characteristics 3.1 Absolute maximum ratings 3.2 Thermal characteristics 3.3 Consumption in typical application scenarios 3.4 Electrical and timing parameters 3.5 Application board curves 4 Power regulators and switch description 4.1 Overview 4.2 LDO regulators 4.2.1 LDO regulators - common features 4.2.2 LDO regulators - special features 4.2.3 LDO output voltage settings 4.3 DDR memory sub-system examples 4.3.1 Powering lpDDR2/lpDDR3 memory 4.3.2 Powering DDR3/DDR3L memory 4.4 Buck converters 4.4.1 BUCK general description 4.4.2 BUCK output voltage settings 4.5 Boost converter and power switches 4.5.1 Boost converter 4.5.2 PWR_USB_SW and PWR_SW power switches 4.6 USB sub-system examples 5 Functional description 5.1 Overview 5.2 Functional state machine 5.2.1 Main state machine diagram 5.2.2 State explanations 5.3 POWER_UP, POWER_DOWN sequence 5.4 Feature description 5.4.1 VIN conditions and monitoring 5.4.2 Turn-ON conditions 5.4.3 Turn-OFF conditions and restart_request 5.4.4 Reset and mask_reset option 5.4.5 Power control modes (MAIN / ALTERNATE) 5.4.6 Thermal protection 5.4.7 Overcurrent protection (OCP) 5.4.8 BOOST overvoltage protection 5.4.9 Watchdog feature 5.5 Programming 5.5.1 I2C interface 5.5.2 Non-volatile memory (NVM) 6 Register description 6.1 User register map 6.2 Status registers 6.2.1 Turn-ON status register (TURN_ON_SR) 6.2.2 Turn-OFF status register (TURN_OFF_SR) 6.2.3 Overcurrent protection LDO turn-OFF status register (OCP_LDOS_SR) 6.2.4 Overcurrent protection buck turn-OFF status register (OCP_BUCKS_BSW_SR) 6.2.5 Restart status register (RESTART_SR) 6.2.6 Version status register (VERSION_SR) 6.3 Control registers 6.3.1 Main control register (MAIN_CR) 6.3.2 Pads pull control register (PADS_PULL_CR) 6.3.3 Bucks pull-down control register (BUCKS_PD_CR) 6.3.4 LDO1-4 pull-down control register (LDO14_PD_CR) 6.3.5 LDO5/6 pull-down control register (LDO56_VREF_PD_CR) 6.3.6 PWR_SWOUT and VIN control register (SW_VIN_CR) 6.3.7 PONKEYn turn-OFF control register (PKEY_TURNOFF_CR) 6.3.8 Mask reset Buck control register (BUCKS_MRST_CR) 6.3.9 Mask reset LDO control register (LDOS_MRST_CR) 6.3.10 Watchdog control register (WDG_CR) 6.3.11 Watchdog timer control register (WDG_TMR_CR) 6.3.12 Bucks OCP turn-OFF control register (BUCKS_OCPOFF_CR) 6.3.13 LDO OCP turn-OFF control register (LDOS_OCPOFF_CR) 6.4 Power supplies control registers 6.4.1 BUCKx MAIN mode control registers (BUCKx_MAIN_CR) (x=1…4) 6.4.2 REFDDR MAIN mode control register (REFDDR_MAIN_CR) 6.4.3 LDOx MAIN mode control registers (LDOx_MAIN_CR) (x=1, 2, 5, 6) 6.4.4 LDO3 MAIN mode control register (LDO3_MAIN_CR) 6.4.5 LDO4 MAIN mode control register (LDO4_MAIN_CR) 6.4.6 BUCKx ALTERNATE mode control registers (BUCKx_ALT_CR)(x=1..4) 6.4.7 REFDDR ALTERNATE mode control register (REFDDR_ALT_CR) 6.4.8 LDOx ALTERNATE mode control registers (LDOx_ALT_CR) (x=1, 2, 5, 6) 6.4.9 LDO3 ALTERNATE mode control register (LDO3_ALT_CR) 6.4.10 LDO4 ALTERNATE mode control register (LDO4_ALT_CR) 6.4.11 Boost/switch control register (BST_SW_CR) 6.5 Interrupt registers 6.5.1 Overall interrupt register behavior 6.5.2 Interrupt pending register 1 (INT_PENDING_R1) 6.5.3 Interrupt pending register 2 (INT_PENDING_R2) 6.5.4 Interrupt pending register 3 (INT_PENDING_R3) 6.5.5 Interrupt pending register 4 (INT_PENDING_R4) 6.5.6 Interrupt debug latch registers (INT_DBG_LATCH_Rx) 6.5.7 Interrupt clear registers (INT_CLEAR_Rx) 6.5.8 Interrupt mask registers (INT_MASK_Rx) 6.5.9 Interrupt set mask registers (INT_SET_MASK_Rx) 6.5.10 Interrupt clear mask registers (INT_CLEAR_MASK_Rx) 6.5.11 Interrupt source register 1 (INT_SRC_R1) 6.5.12 Interrupt source register 2 (INT_SRC_R2) 6.5.13 Interrupt source register 3 ( INT_SRC_R3) 6.5.14 Interrupt source register 4 ( INT_SRC_R4) 6.6 NVM registers 6.6.1 NVM status register (NVM_SR) 6.6.2 NVM control register (NVM_CR) 6.7 NVM shadow registers 6.7.1 NVM main control shadow register (NVM_MAIN_CTRL_SHR) 6.7.2 NVM BUCK rank shadow register (NVM_BUCKS_RANK_SHR) 6.7.3 NVM LDOs rank shadow register 1 (NVM_LDOS_RANK_SHR1) 6.7.4 NVM LDOs rank shadow register 2 (NVM_LDOS_RANK_SHR2) 6.7.5 NVM BUCKs voltage output shadow register (NVM_BUCKS_VOUT_SHR) 6.7.6 NVM LDOs voltage output shadow register 1 (NVM_LDOS_VOUT_SHR1 6.7.7 NVM LDOs voltage output shadow register 2 (NVM_LDOS_VOUT_SHR2) 6.7.8 NVM device address shadow register (I2C_ADDR_SHR) 7 Package information 7.1 WFQFN 44L (5X6X0.8) package information 8 Marking composition 9 Ordering information Revision history
