Datasheet AD8207 (Analog Devices) - 9
DescriptionZero Drift, High Voltage, Bidirectional Difference Amplifier
Pages / Page16 / 9 — AD8207. 600. –40°C. –100. 500. +25°C. IL (mV). +125°C. A R –200. 400. IVE …
File Format / SizePDF / 445 Kb
AD8207. 600. –40°C. –100. 500. +25°C. IL (mV). +125°C. A R –200. 400. IVE IT S O –300. UNT 300. M O. R –400. E F. 200. LTA –500. 100. –600. 0.5. 1.0. 1.5. 2.0. 2.5
AD8207 600 –40°C –100 500 +25°C IL (mV) +125°C A R –200 400 IVE IT S O –300 UNT 300 M O R –400 E F 200 LTA –500 100 –600 0.5 1.0 1.5 2.0 2.5
AD8207 0 600 –40°C –100 500 +25°C IL (mV) +125°C A R –200 400 IVE IT S O –300 P UNT 300 M O CO R –400 E F 200 G LTA –500 VO 100
20 1 23 0- 0 0- 16
–600
16 09 09
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 0 –400 –300 –200 –100 0 100 200 300 400 OUTPUT SOURCE CURRENT (mA) OFFSET (µV)
Figure 21. Output Voltage Range vs. Output Source Current Figure 23. Input Offset Distribution
1000 1000 ) V m 800 800 ND ( U O R G 600 M 600 RO F UNT E CO 400 400 LTAG O V UT P 200 200 T U O
9 24 11 0 0- 0- 16 16
0
09
0
09
0 1 2 3 4 5 6 7 8 –14 –12 –10 –8 –6 –4 –2 0 OUTPUT SINK CURRENT (mA) GAIN DRIFT (ppm/°C)
Figure 22. Output Voltage Range from GND vs. Output Sink Current Figure 24. Gain Drift Distribution Rev. 0 | Page 9 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION POWER SUPPLY ADJUSTMENT 3.3 V TO 4.5 V SUPPLY OPERATION 4.5 V TO 5.5 V SUPPLY OPERATION OUTPUT OFFSET ADJUSTMENT UNIDIRECTIONAL OPERATION Ground Referenced Output Mode V+ Referenced Output Mode BIDIRECTIONAL OPERATION EXTERNAL REFERENCED OUTPUT SPLITTING THE SUPPLY SPLITTING AN EXTERNAL REFERENCE APPLICATIONS INFORMATION MOTOR CONTROL 3-Phase Motor Control H-Bridge Motor Control SOLENOID CONTROL High-Side Current Sense with a Low-Side Switch High-Side Current Sense with a High-Side Switch OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
