Datasheet AD8208 (Analog Devices) - 5
DescriptionHigh Voltage, Precision Difference Amplifier
Pages / Page20 / 5 — Data Sheet. AD8208. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter. Rating. …
RevisionC
File Format / SizePDF / 331 Kb
Data Sheet. AD8208. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter. Rating. ESD CAUTION
Data Sheet AD8208 ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
Data Sheet AD8208 ABSOLUTE MAXIMUM RATINGS Table 2. Parameter Rating
Stresses above those listed under Absolute Maximum Ratings Supply Voltage 12 V may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any Continuous Input Voltage (Common Mode) −24 V to +80 V other conditions above those indicated in the operational Differential Input Voltage ±12 V section of this specification is not implied. Exposure to absolute Reversed Supply Voltage Protection 0.3 V maximum rating conditions for extended periods may affect ESD Human Body Model ±4000 V device reliability. Operating Temperature Range WBR and WBRM Grade −40°C to +125°C WHR and WHRM Grade −40°C to +150°C
ESD CAUTION
Storage Temperature Range −65°C to +150°C Output Short-Circuit Duration Indefinite Lead Temperature Range (Soldering, 10 sec) 300°C Rev. C | Page 5 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information High-Side Current Sensing with a Low-Side Switch High-Rail Current Sensing Low-Side Current Sensing 4 mA to 20 mA Current Loop Receiver Gain Adjustment Gains Less than 20 Gains Greater than 20 Gain Trim Internal Signal Overload Considerations Low-Pass Filtering High Line Current Sensing with LPF and Gain Adjustment Outline Dimensions Ordering Guide Automotive Products
