Datasheet AD8215 (Analog Devices) - 4
DescriptionHigh Voltage, Current Shunt Monitor
Pages / Page13 / 4 — AD8215. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter Rating. …
File Format / SizePDF / 258 Kb
AD8215. Data Sheet. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter Rating. ESD CAUTION
AD8215 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
AD8215 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2. Parameter Rating ESD CAUTION
Supply Voltage 12.5 V Continuous Input Voltage (Survival) −3 V to +68 V Continuous Differential Input Voltage 0.5 V Reverse Supply Voltage −0.3 V ESD Rating HBM ±4000 V Charged Device Model (CDM) ±1000 V Operating Temperature Range −40°C to +125°C Storage Temperature Range −65°C to +150°C Output Short-Circuit Duration Indefinite Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. B | Page 4 of 13 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATION NOTES OUTPUT LINEARITY APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSING WITH A LOW-SIDE SWITCH HIGH-SIDE CURRENT SENSING LOW-SIDE CURRENT SENSING OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
