Datasheet AD8215 (Analog Devices) - 5
Description | High Voltage, Current Shunt Monitor |
Pages / Page | 13 / 5 — Data Sheet. AD8215. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. –IN. … |
Revision | B |
File Format / Size | PDF / 258 Kb |
Data Sheet. AD8215. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. –IN. +IN. GND. TOP VIEW. (Not to Scale). OUT. NC = NO CONNECT
Data Sheet AD8215 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS 1 8 –IN 1 8 +IN GND 2 AD8215 7 NC NC 3 TOP VIEW 6 V+
2
2 6 (Not to Scale)
00
NC 4 5 OUT
3 3- -00
5 5
20 03 07
NC = NO CONNECT
072 Figure 2. Metallization Diagram Figure 3. Pin Configuration
Table 3. Pin Function Descriptions Pin No. Mnemonic X Y Description
1 −IN −228 +519 Inverting Input 2 GND −273 −251 Ground 3, 4, 7 NC Not applicable Not applicable No Connect 5 OUT +265 −466 Buffered Output 6 V+ +273 −266 Supply 8 +IN +229 +519 Noninverting Input Rev. B | Page 5 of 13 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATION NOTES OUTPUT LINEARITY APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSING WITH A LOW-SIDE SWITCH HIGH-SIDE CURRENT SENSING LOW-SIDE CURRENT SENSING OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
