Datasheet AD8216 (Analog Devices)
DescriptionHigh Bandwidth, Bidirectional 65 V Difference Amplifier
Pages / Page16 / 1 — High Bandwidth, Bidirectional. 65 V Difference Amplifier. Data Sheet. …
RevisionC
File Format / SizePDF / 351 Kb
High Bandwidth, Bidirectional. 65 V Difference Amplifier. Data Sheet. AD8216. FEATURES. FUNCTIONAL BLOCK DIAGRAM. ±4000 V HBM ESD
Datasheet AD8216 Analog Devices, Revision: C
High Bandwidth, Bidirectional 65 V Difference Amplifier Data Sheet AD8216 FEATURES FUNCTIONAL BLOCK DIAGRAM ±4000 V HBM ESD V+ Ideal for current shunt applications 6 High common-mode voltage range +IN 8 −4 V to +65 V operating 5 OUT –IN 1 −40 V to +80 V survival 3 MHz bandwidth AD8216 7 VREF1 <100 ns output propagation delay Gain: 3 V/V Wide operating temperature range 3 VREF2 NC 4 Die: −40°C to +150°C 8-lead SOIC: −40°C to +125°C 2
001
GND Adjustable output offset NC = NO CONNECT
07062-
Available in 8-lead SOIC
Figure 1.
Excellent ac and dc performance 10 µV/°C offset drift 10 ppm/°C gain drift Qualified for automotive applications APPLICATIONS High-side current sensing in DC-to-dc converters Motor controls Transmission controls Diesel-injection controls Engine management Suspension controls Vehicle dynamic controls GENERAL DESCRIPTION
The AD8216 is a single-supply, difference amplifier ideal for Excellent ac and dc performance over temperature keep errors amplifying small differential voltages in the presence of large in the measurement loop to a minimum. Offset and gain drift common-mode voltages. The operating input common-mode are guaranteed to a maximum of 20 µV/°C and 15 ppm/°C, voltage range extends from −4 V to +65 V. The typical supply respectively. voltage is 5 V. The AD8216 features a 3 MHz bandwidth, allowing for the input-to-output propagation delay that is The output offset can be adjusted from 0.06 V to 4.9 V with a always less than 150 ns. This feature is ideal for applications 5 V supply by using the VREF1 pin and the VREF2 pin. With the monitoring rapidly increasing and decreasing load currents. VREF1 pin attached to the V+ pin and the VREF2 pin attached to the GND pin, the output is set at half scale. Attaching both VREF1 The AD8216 is offered in a SOIC package. The operating and VREF2 to GND causes the output to be unipolar, starting temperature range is −40°C to +125°C. near ground. Attaching both VREF1 and VREF2 to V+ causes the output to be unipolar, starting near V+. Other offsets can be obtained by applying an external voltage to VREF1 and VREF2.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2007–2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION OUTPUT OFFSET ADJUSTMENT UNIDIRECTIONAL OPERATION GROUND REFERENCED OUTPUT V+ REFERENCED OUTPUT BIDIRECTIONAL OPERATION EXTERNAL REFERENCED OUTPUT SPLITTING THE SUPPLY SPLITTING AN EXTERNAL REFERENCE APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSE WITH A LOW-SIDE SWITCH HIGH-SIDE CURRENT SENSE WITH A HIGH-SIDE SWITCH OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
