Datasheet AD8216 (Analog Devices) - 4
DescriptionHigh Bandwidth, Bidirectional 65 V Difference Amplifier
Pages / Page16 / 4 — AD8216. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. ESD CAUTION. …
RevisionC
File Format / SizePDF / 351 Kb
AD8216. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. ESD CAUTION. Parameter. Rating
AD8216 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 ESD CAUTION Parameter Rating
AD8216 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2. ESD CAUTION Parameter Rating
Supply Voltage 12.5 V Continuous Input Common-Mode Voltage −40 V to +80 V Continuous Input Differential Voltage 6 V Reverse Supply Voltage 0.3 V ESD Rating HBM (Human Body Model) ±4000 V CDM (Charged Device Model) ±1000 V Operating Temperature Range −40°C to +125°C Storage Temperature Range −65°C to +150°C Output Short-Circuit Duration Indefinite Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. C | Page 4 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION OUTPUT OFFSET ADJUSTMENT UNIDIRECTIONAL OPERATION GROUND REFERENCED OUTPUT V+ REFERENCED OUTPUT BIDIRECTIONAL OPERATION EXTERNAL REFERENCED OUTPUT SPLITTING THE SUPPLY SPLITTING AN EXTERNAL REFERENCE APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSE WITH A LOW-SIDE SWITCH HIGH-SIDE CURRENT SENSE WITH A HIGH-SIDE SWITCH OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
