Datasheet 241 (Signal Transformer) - 3
ManufacturerSignal Transformer
DescriptionTwo-4-One Power Transformers. Split Bobbin Construction Providing Superior Isolation
Pages / Page3 / 3 — Mechanical Specifications. Dimensions. Weight. Size. ML (typ). Inches …
Mechanical Specifications. Dimensions. Weight. Size. ML (typ). Inches (mm). lbs (kg). Note:. Custom versions available upon request
Mechanical Specifications Dimensions Weight Size ML (typ) Inches (mm) lbs (kg) Note: Custom versions available upon request
filename ../../../SIGNAL CATALOG/SIGNAL Product Catalog.pdf filename ../../../SIGNAL CATALOG/SIGNAL Product Catalog.pdf filename ../../../SIGNAL CATALOG/SIGNAL Product Catalog.pdf 241 Series Datasheet
Mechanical Specifications Dimensions Weight Size VA L W H A B ML (typ) Inches (mm) lbs (kg)
2.07 1.17 1.23 1.62 0.59 1.75 0.25 3 2.4 (52.6) (29.6) (31.2) (41.3) (15.0) (44.5) (0.11) 2.37 1.31 1.43 1.71 0.72 2.00 0.44 4 6 (60.3) (33.3) (36.2) (43.4) (18.3) (50.8) (0.20) 2.81 1.43 1.69 1.97 0.89 2.37 0.7 5 12 (71.4) (36.3) (42.8) (49.9) (22.6) (60.3) (0.32) 3.25 1.74 1.96 2.35 1.14 2.81 1.1 6 30 (82.6) (44.3) (49.8) (59.7) (28.9) (71.4) (0.50) 3.68 1.94 2.28 2.70 1.14 3.12 1.7 7 56 (93.5) (49.2) (57.8) (68.4) (28.9) (79.4) (0.77) 4.03 2.30 2.58 3.08 1.43 3.56 2.75 8 100 (102.4) (58.5) (65.5) (78.2) (36.2) (90.4) (1.25) Single Primary 115V 50/60 Hz CT CLEARANCE FOR #8 SCREW Dual Primary F2 115/230V S2 50/60 Hz CT F1 115V 50/60 Hz S1 Indicates like polarity
Note:
Agency certified 241 Series transformers with standard length and color lead wires are readily available. See website for 241-L product series.
Custom versions available upon request.
128 Atlantic Avenue, Lynbrook, NY 11563 Toll Free 866-239-5777 | Tel 516-239-5777 | Fax 516-239-7208 sales@signaltransformer.com | techhelp@signaltransformer.com
belfuse.com/signal
© 2019 Signal Transformer Specifications subject to change without notice 241 Series 12.19
