Datasheet TLS715B0NAV50 (Infineon) - 4
Manufacturer | Infineon |
Description | OPTIREG Linear TLS715B0NAV50. Low dropout li near voltage regulator |
Pages / Page | 22 / 4 — OPTIREG™ Linear TLS715B0NAV50 Low dropout linear voltage regulator Block … |
Revision | 01_10 |
File Format / Size | PDF / 686 Kb |
OPTIREG™ Linear TLS715B0NAV50 Low dropout linear voltage regulator Block diagram. Block diagram. GND. Figure 1
OPTIREG™ Linear TLS715B0NAV50 Low dropout linear voltage regulator Block diagram 1 Block diagram I Q
Current Limitation
EN
Enable Bandgap Reference Temperature Shutdown
GND Figure 1 Block diagram TLS715B0NAV50
Datasheet 4 Rev. 1.1 2019-07-31 Document Outline Features Potential applications Product validation Description Table of contents 1 Block diagram 2 Pin configuration 2.1 Pin assignment PG-TSNP-7 2.2 Pin definitions and functions PG-TSNP-7 3 General product characteristics 3.1 Absolute maximum ratings 3.2 Functional range 3.3 Thermal resistance 4 Block description and electrical characteristics 4.1 Voltage regulation 4.2 Typical performance characteristics voltage regulator 4.3 Current consumption 4.4 Typical performance characteristics current consumption 4.5 Enable 4.6 Typical performance characteristics enable 5 Application information 5.1 Application diagram 5.2 Selection of external components 5.2.1 Input pin 5.2.2 Output pin 5.3 Thermal considerations 5.4 Reverse polarity protection 5.5 Further application information 6 Package information 7 Revision history
