Datasheet CMX655D (CML Microcircuits) - 8
ManufacturerCML Microcircuits
DescriptionUltra Low Power Voice Codec
Pages / Page64 / 8 — Figure 3 CMX655D Pin Arrangement
Revision4
File Format / SizePDF / 3.3 Mb
Ultra-Low Power Voice Codec CMX655D A L A 1 D C P P 0 A S S _ T A / / I / / S U N S O K L S O S O SI C V A C M M S 24 23 22 21 20 19 AOUTN 1 18 IRQN VDD_PA 2 17 SPIS LOUT 3 16 BCLK CMX655D VDD_A 4 15 SDO BIAS 5 14 SDI DGND* NC1 6 13 LRCLK/FS 7 8 9 10 11 12 1 2 I N K K D D T L D L A A S C CI C _ _ R C M R D D I D D M V V VQFN (Q6) *Exposed Paddle 4mm x 4mm
 2019 CML Microsystems Plc 8 D/655/4 Document Outline Datasheet Front Page 1 Brief Description 2 Block Diagram 2.1 CMX655D 3 Pin List 3.1 CMX655D 4 External Components 4.1 CMX655D 4.1.1 Power Supply and Pin Decoupling 4.1.2 SPI 4.1.3 TWI 4.1.4 Speaker and Microphone 5 General Description 5.1 Power Management 5.1.1 External Supplies 5.1.2 Regulated Supplies 5.2 Device Reset 5.2.1 Power-On-Reset 5.2.2 Reset Pin 5.3 Main Clock 5.3.1 Clock Frequency 5.3.2 Clock Generation 5.3.3 PLL 5.3.4 Low Power Oscillator 5.3.5 Clock Control Registers 5.3.5.1 CLKCTRL ($03) 5.3.5.2 RDIVHI ($04) 5.3.5.3 RDIVLO ($05) 5.3.5.4 NDIVHI ($06) 5.3.5.5 NDIVLO ($07) 5.3.5.6 PLLCTRL ($08) 5.4 Microphone Interface 5.4.1 Digital Microphone Interface 5.5 Class-D Amplifier 5.5.1 Audio Outputs 5.5.2 Overload Current Protection 5.5.3 Thermal Protection 5.5.4 Clipping Detection 5.6 Audio Signal Processing 5.6.1 Record Level Control 5.6.1.1 Record Level Control Register 5.6.2 Noise Gate 5.6.2.1 Noise Gate Registers 5.6.3 Record Level Detection 5.6.3.1 Record Level Detection Registers 5.6.4 Playback Preamplifier Gain 5.6.4.1 Playback Preamplifier Gain Register 5.6.5 Playback Volume Control 5.6.5.1 Playback Volume Register 5.6.6 Automatic Level Control 5.6.6.1 ALC Registers 5.6.7 Digital Sidetone 5.6.7.1 Digital Sidetone Register 5.6.8 Voice Filters 5.6.8.1 Low Pass Filter 5.6.8.2 DC Blocking Filter 5.6.8.3 High Pass Filter 5.6.8.4 Voice Filters Registers 5.6.9 Channel Multiplexing 5.6.10 Click-and-Pop Reduction 5.6.10.1 Click-and-Pop Reduction Register 5.7 Control Interface 5.7.1 SPI Slave 5.7.2 TWI Slave 5.8 Serial Audio Interface 5.8.1 I2S Mode 5.8.2 Left-Justified Mode 5.8.3 PCM Mode 5.8.4 Audio Companding 5.8.5 Serial Audio Interface Registers 5.9 Interrupt Status and IRQN Pin 5.9.1 Interrupt Registers 5.10 System Control 5.10.1 System Control Registers 5.11 Register Address Map 6 Application Notes 6.1 Programming Examples 6.1.1 Start-up 6.1.2 Configuration 6.1.3 Enable Audio Channels 6.1.4 Shutdown 7 Performance Specification 7.1 Electrical Performance 7.1.1 Absolute Maximum Ratings 7.1.2 Operating Limits 7.1.3 Operating Characteristics 7.1.3.1 DC Parameters 7.1.3.2 AC Parameters 7.1.3.3 SPI 7.1.3.4 TWI 7.1.3.5 SAI 7.1.3.6 Digital Microphone Interface 7.2 Typical Performance Characteristics 7.2.1 THD+N vs. Level performance 7.2.2 THD+N vs. Frequency performance 7.2.3 Class D Amplifier Efficiency 7.2.4 Filter Performance Speaker Channel 7.2.5 Filter Performance Microphone Channel 7.3 Packaging 7.3.1 CMX655D End of Document cmlmicro.com CMX655D - Ultra-low Power Voice Codec - CML Micro
