Datasheet LPSA 600 (Vishay) - 3
ManufacturerVishay
DescriptionPower Resistor for Mounting Onto a Heatsink Thick Film Technology
Pages / Page6 / 3 — LPSA 600. RECOMMENDATIONS FOR MOUNTING ONTO A HEATSINK. Tightening Torque …
File Format / SizePDF / 112 Kb
LPSA 600. RECOMMENDATIONS FOR MOUNTING ONTO A HEATSINK. Tightening Torque on Heatsink. CHOICE OF THE HEATSINK. Example:
LPSA 600 RECOMMENDATIONS FOR MOUNTING ONTO A HEATSINK Tightening Torque on Heatsink CHOICE OF THE HEATSINK Example:
LPSA 600
www.vishay.com Vishay Sfernice
• Surfaces in contact must be carefully cleaned. • The heatsink must have an acceptable flatness: From 0.05 mm to 0.1 mm/100 mm. • Roughness of the heatsink must be around 6.3 μm. In order to improve thermal conductivity, surfaces in contact (alumina, heatsink) should be coated with a silicone grease (type Bluesil Past 340 from BlueStar Silicones) or a thermal film (type Q pad II) easier and faster to install than the grease. • The fastening of the resistor to the heatsink is under pressure control of two screws tightened at 2 Nm for full power availability. LPSA 600
2 Nm • The following accessories are supplied with each product: - 2 screws CHC M4 x 25 class 8.8 and 2 M4 contact lock washers for heatsink mounting - 2 screws TH M4 x 6/6 and 2 M4 contact lock washers for connections
The user must choose the heatsink according to the working conditions of the component (power, room temperature). Maximum working temperature must not exceed 155 °C. The dissipated power is simply calculated by the following ratio: T P = ---------------------------------------------- R + R + R TH (j - c) TH (c - h) TH (h - a) P: Expressed in W T: Difference between maximum working temperature and room temperature RTH (j - c): Thermal resistance value measured between resistive layer and outer side of the resistor. It is the thermal resistance of the component: (see specifications environmental paragraph). RTH (c - h): Thermal resistance value measured between outer side of the resistor and upper side of the heatsink. This is the thermal resistance of the interface (grease, thermal pad), and the quality of the fastening device. RTH (h - a): Thermal resistance of the heatsink.
Example:
RTH (c - a) for LPSA 600 power dissipation 180 W at + 50 °C room temperature. T  155 °C - 50 °C = 105 °C T 105 RTH (j - c) + RTH (c - h) + RTH (h - a) = ---- = ------- = 0.58 °C/W P 180 RTH (j - c) = 0.112 °C/W RTH (c - h) + RTH (h - a) = 0.58 °C/W - 0.112 °C/W = 0.468 °C/W
OVERLOADS
In any case the applied voltage must be lower than UL = 5000 V.
Short time overload:
2 x Pr/10 s
Accidental overload:
The values indicated on the following graph are applicable to resistors in air or mounted onto a heatsink. Revision: 21-Nov-2019
3
Document Number: 50077 For technical questions, contact: sferfixedresistors@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
