A product Line of Diodes Incorporated PI6CG33402CCrystal Circuit Connection The following diagram shows PI6CG33402C crystal circuit connection with a parallel crystal. For the CL = 8pF crystal, it is suggested to use C1 = 8pF, C2 = 8pF. C1 and C2 can be adjusted to fine tune to the target ppm of crystal oscillator according to different board layouts based on the following formula in the Crystal Capacitor Calculation diagram. Crystal Oscillator Circuit XTAL_IN C1 8pF FL2500262Q Crystal�(C =�8pF) L� XTAL_OUT C2 8pF Crystal Capacitor CalculationXTAL_INXTAL_OUTCL= crystal spec. loading cap.Cj = chip in/output cap. (3~5pF)CjCjCb = PCB trace/via cap. (2~4pF)Rf PseudoRdC1, C2 = load cap. componentsCbsineRd = drive level res. (100Ω)CbC1C2Final choose/trim C1=C2=2 *CL - (Cb +Cj) for the target +/-ppmExample: C1=C2=2*(18pF) – (4pF+5pF)=27pFRecommended Crystal Specification Diodes recommends: a) FL2500217, SMD 3.2x2.5(4P), 25MHz, CL=8pF, +/-20ppm, https://www.diodes.com/assets/Datasheets/FL.pdf b) FH2500016, SMD 2.5x2.0(4P), 25MHz, CL=8pF, +/-30ppm, https://www.diodes.com/assets/Datasheets/FH.pdf c) FW2500031, SMD 2.0x1.6(4P), 25MHz, CL=8pF, +/-30ppm, https://www.diodes.com/assets/Datasheets/FW.pdf d) US2500003, SMD 1.6x1.2(4P), 25MHz, CL=12pF, +/-30ppm, https://www.diodes.com/assets/Datasheets/US.pdf PI6CG33402C www.diodes.com January 2020 Document Number DS42294 Rev 3-2 21 Diodes Incorporated
