A product Line of Diodes Incorporated PI6CB33402SMBus Address Selection TableSADRAddress+Read/Write Bit 0 1101011 X State of SADR on first application of PD# M 1101100 X 1 1101101 X Power Management TablePD#INSMBus OE bitOEn#Qn+Qn-PLL Status 0 X X X Low(2) Low(2) Off 1 Running 0 X Low(2) Low(2) On(1) 1 Running 1 0 Running Running On(1) 1 Running 1 1 Low(2) Low(2) On(1) Note: 1. If PLL Bypass mode is selected, the PLL will be off and outputs will be running. 2. The output state is set by B11[1:0] (Low/Low default) PLL Operating Mode Select TableBW_SEL_TRIOperating ModeByte1 [7:6] ReadbackByte1 [4:3] Control 0 PLL with low Bandwidth 00 00 M PLL Bypass 01 01 1 PLL with high Bandwidth 11 11 Frequency Select tableFreq. Select Byte 3 [4:3]IN (MHz)Qn (MHz) 00 (default) 100 100 01 50 50 10 125 125 11 133.33 133.33 PI6CB33402 www.diodes.com January 2020 Document Number DS41293 Rev 5-2 4 Diodes Incorporated
