Datasheet IR3888 OptiMOS IPOL (Infineon) - 6
Manufacturer | Infineon |
Description | 25 A single-voltage synchronous Buck regulator |
Pages / Page | 49 / 6 — IR 888 OptiMOS™ IPOL. 25 A single-voltage synchronous Buck regulator. … |
Revision | 01_00 |
File Format / Size | PDF / 2.7 Mb |
IR 888 OptiMOS™ IPOL. 25 A single-voltage synchronous Buck regulator. Typical application diagram
IR 888 OptiMOS™ IPOL 25 A single-voltage synchronous Buck regulator Typical application diagram 3 Typical application diagram
4.3V<Vin< 17V Enable Enable Vin PVin Boot Vcc/LDO Vo SW Cff NC PGood Fb PGood IR3888 RFB1 RFB2 SS/Latch VSENM TON/MODE RFB2 ILIM VSNS AGnd RFB1 PGnd
Figure 3 IR3888 basic application circuit
Final Datasheet 6 of 49 V2.1 2019-12-11 Document Outline Revision History Trademarks Disclaimer
