Datasheet IR3889 IR OptiMOS IPOL (Infineon) - 6
Manufacturer | Infineon |
Description | A single-voltage synchronous Buck regulator |
Pages / Page | 50 / 6 — OptiMOS™ IPOL. 30 A single-voltage synchronous Buck regulator. Typical … |
Revision | 02_04 |
File Format / Size | PDF / 2.9 Mb |
OptiMOS™ IPOL. 30 A single-voltage synchronous Buck regulator. Typical application diagram
IR OptiMOS™ IPOL 30 A single-voltage synchronous Buck regulator Typical application diagram 3 Typical application diagram
PVin Enable EN Vin PVin BOOT VCC/LDO PHASE VDRV Vo SW PGood PGood IR3889 NC 0.1uF SS/Latch GATEL FB TON/MODE Cff ILIM VSENM AGND PGND NC NC NC R R FB2 FB1
Figure 3 IR3889 basic application circuit
Final Datasheet 6 of 50 V2.4 2020-1-16 Document Outline Revision History Trademarks Disclaimer
