Datasheet LTM8063 (Analog Devices)
Description40VIN, 2A Silent Switcher µModule Regulator
Pages / Page24 / 1 — FEATURES. DESCRIPTION. Low Noise Silent Switcher. Architecture. Wide …
RevisionC
File Format / SizePDF / 2.6 Mb
FEATURES. DESCRIPTION. Low Noise Silent Switcher. Architecture. Wide Input Voltage Range: 3.2V to 40V
Datasheet LTM8063 Analog Devices, Revision: C
LTM8063 40VIN, 2A Silent Switcher µModule Regulator
FEATURES DESCRIPTION
n
Architecture
The LTM®8063 is a 40VIN, 2A continuous, 2.5A peak, step- n
down µModule® (power module) regulator. Included in n
Wide Output Voltage Range: 0.8V to 15V
the package are the switching controller, power switches, n
2A Continuous Output Current at 12VIN, 5VOUT,
inductor, and all support components. Operating over an
TA = 85°C
input voltage range of 3.2V to 40V, the LTM8063 supports n
2.5A Peak Current
an output voltage range of 0.8V to 15V and a switching n Selectable Switching Frequency: 200kHz to 2.2MHz frequency range of 200kHz to 2.2MHz, each set by a single n External Synchronization resistor. Only the input and output filter capacitors are n Configurable as an Inverter needed to finish the design. n 6.25mm × 4mm × 2.22mm BGA Package The low profile package enables utilization of unused
space on the bottom of PC boards for high density point of load regulation. The LTM8063 is packaged in a thermally n enhanced, compact over-molded ball grid array (BGA) pack- Automotive Battery Regulation n age suitable for automated assembly by standard surface Power for Portable Products n mount equipment. The LTM8063 is RoHS compliant. Distributed Supply Regulation All registered trademarks and trademarks are the property of their respective owners. n Industrial Supplies n Wall Transformer Regulation
TYPICAL APPLICATION Efficiency vs Load Current 5V
95
OUT from 6.5VIN to 40VIN Step-Down Converter
V V IN IN LTM8063 6.5V TO 40V 85 RUN 1µF V V OUT OUT 5V 2A 75 RT 22µF 2.5A PEAK 27.4k 45.3k EFFICIENCY (%) 1.4MHz GND SYNC FB 65 8063 TA01a 12VIN 24VIN PINS NOT USED IN THIS CIRCUIT: TR/SS, PG 36VIN 55 0 0.5 1 1.5 2 2.5 LOAD CURRENT (A) 8063 TA01b Rev C Document Feedback For more information www.analog.com 1 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Photo Package Description Revision History Typical Application Related Parts
