Datasheet TMP03, TMP04 (Analog Devices)
Description | Serial Digital Output Thermometers |
Pages / Page | 17 / 1 — Serial Digital Output Thermometers. TMP03/TMP04. FEATURES. FUNCTIONAL … |
Revision | B |
File Format / Size | PDF / 316 Kb |
Serial Digital Output Thermometers. TMP03/TMP04. FEATURES. FUNCTIONAL BLOCK DIAGRAM
a
Serial Digital Output Thermometers TMP03/TMP04 FEATURES FUNCTIONAL BLOCK DIAGRAM Low Cost 3-Pin Package Modulated Serial Digital Output TMP03/TMP04 Proportional to Temperature TEMPERATURE 1.5 C Accuracy (typ) from –25 C to +100 C SENSOR Specified –40 C to +100 C, Operation to 150 C Power Consumption 6.5 mW Max at 5 V VPTAT Flexible Open-Collector Output on TMP03 DIGITAL CMOS/TTL-Compatible Output on TMP04 MODULATOR VREF Low Voltage Operation (4.5 V to 7 V) APPLICATIONS 1 2 3 Isolated Sensors DOUT V+ GND Environmental Control Systems Computer Thermal Monitoring Thermal Protection Industrial Process Control Power System Monitors PACKAGE TYPES AVAILABLE TO-92 GENERAL DESCRIPTION
The TMP03/TMP04 are monolithic temperature detectors that generate a modulated serial digital output that varies in direct
TMP03/TMP04
proportion to the temperature of the device. An onboard sensor generates a voltage precisely proportional to absolute tempera-
1 2 3
ture which is compared to an internal voltage reference and
D V+ OUT GND
input to a precision digital modulator. The ratiometric encoding
BOTTOM VIEW (Not to Scale)
format of the serial digital output is independent of the clock drift errors common to most serial modulation techniques such as voltage-to-frequency converters. Overall accuracy is ± 1.5°C (typical) from –25°C to +100°C, with excellent transducer lin- earity. The digital output of the TMP04 is CMOS/TTL compatible, and is easily interfaced to the serial inputs of most
SO-8
popular microprocessors. The open-collector output of the TMP03 is capable of sinking 5 mA. The TMP03 is best suited
D 1 8
for systems requiring isolated circuits utilizing optocouplers or
OUT NC TMP03/
isolation transformers.
V+ 2 7 TMP04 NC GND 3 TOP VIEW 6 NC
The TMP03 and TMP04 are specified for operation at supply
(Not to Scale)
voltages from 4.5 V to 7 V. Operating from 5 V, supply current
NC 4 5 NC
(unloaded) is less than 1.3 mA.
NC = NO CONNECT
The TMP03/TMP04 are rated for operation over the –40°C to +100°C temperature range in the low cost TO-92, SO-8, and TSSOP-8 surface mount packages. Operation extends to 150°C with reduced accuracy. (continued on page 4)
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2002–2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline RevHistory_TMP03_04.pdf REVISION HISTORY
