Datasheet TMP03, TMP04 (Analog Devices) - 3
DescriptionSerial Digital Output Thermometers
Pages / Page17 / 3 — TMP03/TMP04. ABSOLUTE MAXIMUM RATINGS*. Package Type. Units. *CAUTION. …
File Format / SizePDF / 316 Kb
TMP03/TMP04. ABSOLUTE MAXIMUM RATINGS*. Package Type. Units. *CAUTION. ORDERING GUIDE. Model1. Temperature Range. Package Description
TMP03/TMP04 ABSOLUTE MAXIMUM RATINGS* Package Type Units *CAUTION ORDERING GUIDE Model1 Temperature Range Package Description
Maximum Supply Voltage . 9 V
Package Type JA JC Units
Maximum Output Current (TMP03 DOUT) . 50 mA Maximum Output Current (TMP04 D T-3-1 1621 120 °C/W OUT) . 10 mA Maximum Open-Collector Output Voltage (TMP03) . 18 V R-8 1581 43 °C/W Operating Temperature Range . –55°C to +150°C NOTE 1 Dice Junction Temperature . 175°C ΘJA is specified for device in socket (worst case conditions). Storage Temperature Range . –65°C to +160°C Lead Temperature (Soldering, 60 sec) . 300°C
*CAUTION
1Stresses above those listed under Absolute Maximum Ratings may cause perma- nent damage to the device. This is a stress rating only; functional operation at or above this specification is not implied. Exposure to the above maximum rating conditions for extended periods may affect device reliability. 2Digital inputs and outputs are protected, however, permanent damage may occur on unprotected units from high-energy electrostatic fields. Keep units in conduc- tive foam or packaging at all times until ready to use. Use proper antistatic handling procedures. 3Remove power before inserting or removing units from their sockets.
ORDERING GUIDE Model1 Temperature Range Package Description Package Option
TMP03FS −40°C to +85°C 8-Lead SOIC_N R-8 TMP03FSZ −40°C to +85°C 8-Lead SOIC_N R-8 TMP03FSZ-REEL −40°C to +85°C 8-Lead SOIC_N R-8 TMP03FT9 −40°C to +85°C 3-Lead TO-92 T-3-1 TMP03FT9Z −40°C to +85°C 3-Lead TO-92 T-3-1 TMP04FS −40°C to +85°C 8-Lead SOIC_N R-8 TMP04FS-REEL −40°C to +85°C 8-Lead SOIC_N R-8 TMP04FSZ −40°C to +85°C 8-Lead SOIC_N R-8 TMP04FSZ-REEL −40°C to +85°C 8-Lead SOIC_N R-8 TMP04FT9 −40°C to +85°C 3-Lead TO-92 T-3-1 TMP04FT9Z −40°C to +85°C 3-Lead TO-92 T-3-1 1 Z = RoHS Compliant Part.
CAUTION
ESD (electrostatic discharge) sensitive device. Electrostatic charges as high as 4000 V readily accumulate on the human body and test equipment and can discharge without detection.
WARNING!
Although the TMP03 features proprietary ESD protection circuitry, permanent damage may occur on devices subjected to high-energy electrostatic discharges. Therefore, proper ESD
ESD SENSITIVE DEVICE
precautions are recommended to avoid performance degradation or loss of functionality. REV. B –3– Document Outline RevHistory_TMP03_04.pdf REVISION HISTORY
