EL7801Typical Application DiagramVBATVINVHIFAULTSWD1VBATSWD2VDCVDCVOUT0.1µFTEMPBOOST/BUCKNSENSORTEMPSWS1TMAXSWS2PWMEN/PWMFBMODEENLLEVELGND1VBOOST MODEFIGURE 1. TYPICAL APPLICATION CIRCUITPin DescriptionsPINNAMEDESCRIPTION 1 VDC Internally regulated 5V supply, tracks VIN for input voltages less than 5V 2 VHI Power FET gate drive supply 3 VOUT Overvoltage monitor input; tie to VOUT for normal operation 4 SWD1 NMOS power FET drain 5 SWD2 NMOS power FET drain 6 BOOST/BUCKN Digital input, configures controller to operate in BOOST or BUCK mode, low for BOOST, high for BUCK 7 LEVEL Sets LED bias current level; VFB(nominal) = VLEVEL/5 8 TEMP Temperature reference, tie to GND to disable temperature compensation, tie to VDC to enable camera flash mode 9 FB LED current feedback 10 TMAX Maximum LED temperature set point; If TEMP voltage exceeds TMAX, FB set point is reduced 11 SWS2 NMOS power FET source 12 SWS1 NMOS power FET source 13 EN/PWM Chip enable, light modulation PWM input 14 MODE Digital Input; tie to GND to set FB reference to 400mV, tie to VDC to control FB reference with LEVEL input 15 ENL LED load isolation switch gate driver 16 VBAT Input supply monitor 17 N/C Leave floating (internally connected) 18 GND Ground return and FB ground reference 19 FAULT Gate drive of fault FET. Driven low under fault conditions 20 VIN Input supply and FB pin supply reference 4 FN7354.0 December 22, 2005
