DatasheetsDatasheet STK984-090A-E (ON Semiconductor)
Manufacturer | ON Semiconductor |
Description | 20A/40V Integrated Power Module in SIP23 package |
Pages / Page | 19 / 1 — STK984-090A-E. 20A/40V Integrated Power Module. in SIP23 package |
Revision | 2 |
File Format / Size | PDF / 687 Kb |
![Datasheet STK984-090A-E ON Semiconductor, Revision: 2](https://www.rlocman.ru/datasheet/img.php?di=168307)
STK984-090A-E
in SIP23 package
The STK984-090A-E is a fully-integrated inverter power stage consisting
of a gate driver, six MOSFET’s and a high-side shunt resistor, suitable for
driving permanent magnet synchronous (PMSM) motors and brushlessDC (BLDC) motors. The MOSFET’s are configured in a 3-phase bridge
with a single drain connection for the lower legs. The power stage has a
full range of protection functions including cross-conduction protection,
external shutdown and undervoltage lockout. www.onsemi.com PACKAGE PICTURE Features Module with six 40V/20A MOSFETs, driver and sense resistor
59.8mm 26.7mm single in-line package with 90° lead bend
Built-in charge pump for operation with low battery voltage
Over-current protection on both high-side and low-side MOSFETs
Over-temperature shutdown
Undervoltage and overvoltage shutdown for defined operation at all
input voltages Integrated high-side resistor for external current sensing SIP23 / SIP2E 2nd
MARKING DIAGRAM Typical Applications Automotive Fans Automotive Pumps STK984-090A-E = Specific Device Code
A = Year
B = Month
C = Production Site
DD = Factory Lot Code PIN CONNECTIONS ORDERING INFORMATION
Figure 1: Functional Diagram
Device
STK984-090A-E © Semiconductor Components Industries, LLC, 2016 March 2016 -Rev. 2 1 Package
SIP23 / SIP2E 2nd
(Pb-Free) Shipping
(Qty / Packing)
9 / Tube Publication Order Number:
STK984-090A-E/D
