Datasheet LTC7060 (Analog Devices) - 6
Description | 100V Half Bridge Driver with Floating Grounds and Programmable Dead-Time |
Pages / Page | 18 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. … |
File Format / Size | PDF / 1.4 Mb |
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Propagation Delay vs Floating. Propagation Delay
LTC7060
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Propagation Delay vs Floating Propagation Delay Propagation Delay vs Propagation Delay Supply Voltage vs Floating Supply Voltage Temperature vs Temperature Dead-Time vs RDT
60 50 80 VCC = BGVCC = BST =10V BGRTN = SW = 0V tPL(EN) 50 70 NO LOAD 40 Y (ns) Y (ns) 40 tPL(EN) tPH(EN) 60 30 TION DELA 30 TION DELA 50 t AGA PH(EN) AGA DEAD–TIME (ns) PROP t 20 t PHL(BG) 20 PROP PHL(BG) 40 tPHL(TG) tPHL(TG) 10 10 30 4 6 8 10 12 14 –45 –20 5 30 55 80 105 130 155 0 20 40 60 80 100 VBGVCC–BGRTN, VBST–SW (V) TEMPERATURE (°C) RDT (kΩ) 7060 G10 7060 G11 7060 G12
Dead-Time vs Floating Supply Dead–T Voltage Dead-Time vs T Dead–T emperature ime vs T
100 80 BGVCC = BST =10V BGRTN = SW = 0V 70 80 NO LOAD tPLH(BG/TG), RDT = 64.9kΩ 60 tPLH(BG/TG), RDT = 64.9kΩ 60 50 tPLH(BG/TG), RDT = 24.9kΩ tPLH(BG/TG), RDT = 24.9kΩ DEAD–TIME (ns) DEAD–TIME (ns) 40 40 30 tPLH(BG/TG), RDT = 0Ω tPLH(BG/TG), RDT = 0Ω 20 20 4 6 8 10 12 14 –45 –20 5 30 55 80 105 130 155 VBGVCC–BGRTN, VBST–SW (V) TEMPERATURE (°C) 7060 G13 7060 G14
TG/BG Pull-Up and Pull-Down TG/BG Pull-Up and Pull-Down TG/BG Pull–Up and Pull–Down Resistance vs Floating Supply TG/BG Pull–Up and Pull–Down Resistance vs Temperature Voltage Resistance vs Floating Supply Voltage
3 3 BGVCC = BST =10V BGRTN = SW = 0V 2 2 RUP(BG), RUP(TG) IMPEDANCE (Ω) 1 IMPEDANCE (Ω) 1 RUP(TG) R R DOWN(TG) DOWN(BG), RDOWN(TG) RUP(BG) RDOWN(BG) 0 0 –45 –20 5 30 55 80 105 130 155 4 6 8 10 12 14 TEMPERATURE (°C) VBGVCC–BGRTN, VBST–SW (V) 7060 G15 7060 G16 Rev. 0 6 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Timing Diagram Operation Applications InformatioN Typical Applications Package Description Typical Application Related Parts
