Datasheet ES8311 (Everest Semiconductor) - 7
ManufacturerEverest Semiconductor
DescriptionLow Power Mono Audio CODEC
Pages / Page12 / 7 — Everest Semiconductor. Confidential. ES8311. 6. DIGITAL AUDIO INTERFACE
File Format / SizePDF / 558 Kb
Everest Semiconductor Confidential ES8311 6 DIGITAL AUDIO INTERFACE
Everest Semiconductor Confidential ES8311 6. DIGITAL AUDIO INTERFACE
The device provides many formats of serial audio data interface to the input of the DAC or output from the ADC through LRCK, SCLK and DSDIN or ASDOUT pins. These formats are I2S, left justified, right justified and DSP/PCM. DAC input DSDIN is sampled by the device on the rising edge of SCLK. ADC data is out at ASDOUT on the fal ing edge of SCLK. The relationship of SDATA (DSIN/ASDOUT), SCLK and LRCK with these formats are shown through Figure 2a to Figure 2d. 1 SCLK 1 SCLK LRCK L Channel R Channel SCLK SDATA MSB LSB MSB LSB Fig ure 2a I2S Serial Audio Dat a Format LRCK L Channel R Channel SCLK SDATA MSB LSB MSB LSB Fig ure 2b Left Justified Serial Audio Data For mat 1 SCLK LRCK L Channel R Channel SCLK SDATA MSB LSB MSB LSB Figure 2 c DSP/PCM Mode A Serial Audio Data Format LRCK L Channel R Channel SCLK SDATA MSB LSB MSB LSB Figur e 2d DSP/PCM M ode B Serial Audio Data Format Revision 7.0 7 January 2020 Latest datasheet: www.everest-semi.com or info@everest-semi.com Document Outline Block Diagram Pin Out and Description typical APPLICATION CIRCUIT Clock Modes and Sampling Frequencies Micro-controller configuration Interface Digital Audio Interface ELECTRICAL CHARACTERISTICS Absolute Maximum Ratings Recommended Operating Conditions ADC Analog and Filter Characteristics and Specifications DAC Analog and Filter Characteristics and Specifications DC Characteristics Serial Audio Port Switching Specifications I2C Switching Specifications (slow speed mode/high speed mode) Package CORPORATe INFORMATION
