Datasheet SMBJ12(C)AQ – SMBJ100(C)AQ (Diodes) - 3
ManufacturerDiodes
Description600W Surface Mount Automotive Transient Voltage Suppressor
Pages / Page6 / 3 — SMBJ12(C)AQ – SMBJ100(C)AQ. Electrical Characteristics. Part Number. …
File Format / SizePDF / 356 Kb
SMBJ12(C)AQ – SMBJ100(C)AQ. Electrical Characteristics. Part Number. Reverse. Breakdown. Max Reverse. Max Clamping. Add C for Bi-
SMBJ12(C)AQ – SMBJ100(C)AQ Electrical Characteristics Part Number Reverse Breakdown Max Reverse Max Clamping Add C for Bi-
(@TA = +25°C, unless otherwise specified.)
Part Number Reverse Breakdown Max Reverse Max Clamping Add C for Bi- Standoff Voltage Test Max. Peak Pulse Current Voltage @ Ipp Current Marking Code Directional Voltage V Leakage @ VRWM BR @ IT (Note 10) (Note 11) (Note 9) VRWM (V) Min (V) Max (V) IT (mA) IR (µA) VC (V) Ipp (A) BI- UNI-
SMBJ12(C)AQ 12.0 13.30 15.30 1.0 5.0 19.9 30.2 BE LE SMBJ14(C)AQ 14.0 15.60 17.90 1.0 5.0 23.2 25.8 BK LK SMBJ15(C)AQ 15.0 16.70 19.20 1.0 5.0 24.4 24.0 BM LM SMBJ16(C)AQ 16.0 17.80 20.50 1.0 5.0 26.0 23.1 BP LP SMBJ17(C)AQ 17.0 18.90 21.70 1.0 5.0 27.6 21.7 BR LR SMBJ18(C)AQ 18.0 20.00 23.30 1.0 5.0 29.2 20.5 BT LT SMBJ20(C)AQ 20.0 22.20 25.50 1.0 5.0 32.4 18.5 BV LV SMBJ22(C)AQ 22.0 24.40 28.00 1.0 5.0 35.5 16.9 BX LX SMBJ24(C)AQ 24.0 26.70 30.70 1.0 5.0 38.9 15.4 BZ LZ SMBJ26(C)AQ 26.0 28.90 33.20 1.0 5.0 42.1 14.2 CE ME SMBJ28(C)AQ 28.0 31.10 35.80 1.0 5.0 45.4 13.2 CG MG SMBJ30(C)AQ 30.0 33.30 38.30 1.0 5.0 48.4 12.4 CK MK SMBJ33(C)AQ 33.0 36.70 42.20 1.0 5.0 53.3 11.3 CM MM SMBJ36(C)AQ 36.0 40.00 46.00 1.0 5.0 58.1 10.3 CP MP SMBJ51(C)AQ 51.0 56.70 65.20 1.0 5.0 82.4 7.3 CZ MZ SMBJ58(C)AQ 58.0 64.40 74.60 1.0 5.0 93.6 6.4 DG NG SMBJ70(C)AQ 70.0 77.80 89.50 1.0 5.0 113.0 5.3 DP NP SMBJ100(C)AQ 100.0 111.0 128.00 1.0 5.0 162.0 3.7 DZ NZ Notes: 9. Suffix C denotes bidirectional device. 10. VBR measured with IT current pulse = 10ms to 15ms. 11. Per 10 × 1000μs waveform. See Figure 4. SMBJ12(C)AQ – SMBJ100(C)AQ 3 of 6 March 2020 Document number: DS40740 Rev. 4 - 2
www.diodes.com
© Diodes Incorporated Document Outline Features and Benefits Product Summary (@TA = +25°C) Description and Applications Mechanical Data Marking Information Thermal Characteristics Package Outline Dimensions (Note 12) Suggested Pad Layout
