Datasheet NCP500, NCV500 (ON Semiconductor)
Manufacturer | ON Semiconductor |
Description | Voltage Regulator - CMOS, Low Noise, Low-Dropout 150 mA |
Pages / Page | 18 / 1 — www.onsemi.com. TSOP−5. DFN 2x2.2 MM. SN SUFFIX. SQL SUFFIX. CASE 483. … |
Revision | 22 |
File Format / Size | PDF / 199 Kb |
www.onsemi.com. TSOP−5. DFN 2x2.2 MM. SN SUFFIX. SQL SUFFIX. CASE 483. CASE 506BA. Features. PIN CONNECTIONS AND. MARKING DIAGRAMS
link to page 16 NCP500, NCV500 Voltage Regulator - CMOS, Low Noise, Low-Dropout 150 mA The NCP500 series of fixed output low dropout linear regulators are designed for portable battery powered applications which require low
www.onsemi.com
noise operation, fast enable response time, and low dropout. The device achieves its low noise performance without the need of an 6 external noise bypass capacitor. Each device contains a voltage 5 reference unit, an error amplifier, a PMOS power transistor, and resistors for setting output voltage, and current limit and temperature 1 1 limit protection circuits.
TSOP−5 DFN 2x2.2 MM
The NCP500 has been designed to be used with low cost ceramic
SN SUFFIX SQL SUFFIX
capacitors and requires a minimum output capacitor of 1.0 mF.
CASE 483 CASE 506BA Features
• Ultra−Low Dropout Voltage of 170 mV at 150 mA
PIN CONNECTIONS AND
• Fast Enable Turn−On Time of 20 msec
MARKING DIAGRAMS
• Wide Operating Voltage Range of 1.8 V to 6.0 V •
TSOP−5
Excellent Line and Load Regulation • High Accuracy Output Voltage of 2.5% Vin 1 xxxA 5 Vout • Enable Can Be Driven Directly by 1.0 V Logic G YW • GND 2 Typical RMS Noise Voltage 50 mV with No Bypass Capacitor G (BW = 10 Hz to 100 kHz) Enable 3 4 N/C • Very Small DFN 2x2.2 Package • (Top View) NCV Prefix for Automotive and Other Applications Requiring Unique Site and Control Change Requirements; AEC−Q100 xxx = Specific Device Code Qualified and PPAP Capable A = Assembly Location • These are Pb−Free Devices Y = Year W = Work Week
Typical Applications
G = Pb−Free Package • (Note: Microdot may be in either location) Noise Sensitive Circuits − VCO’s, RF Stages, etc. • SMPS Post−Regulation
DFN 2x2.2 mm
• Hand−Held Instrumentation • Camcorders and Cameras Enable 1 6 N/C GND 2 xxM 5 GND Vin Vout V 1 (3) 5 (4) in 3 4 Vout Driver w/ (Top View) Thermal Current Shutdown Limit xx = Specific Device Code M = Date Code Enable ON 3 (1)
ORDERING INFORMATION
See detailed ordering and shipping information in the package dimensions section on page 16 of this data sheet. OFF GND 2 (2, 5) NOTE: Pin numbers in parenthesis indicate DFN package.
Figure 1. Simplified Block Diagram
© Semiconductor Components Industries, LLC, 2015
1
Publication Order Number:
October, 2019 − Rev. 22 NCP500/D
