Datasheet NCP500, NCV500 (ON Semiconductor) - 15
ManufacturerON Semiconductor
DescriptionVoltage Regulator - CMOS, Low Noise, Low-Dropout 150 mA
Pages / Page18 / 15 — NCP500, NCV500. Figure 32. Delayed Turn−on. Figure 33. Delayed Turn−on. …
Revision22
File Format / SizePDF / 199 Kb
NCP500, NCV500. Figure 32. Delayed Turn−on. Figure 33. Delayed Turn−on. Figure 34. Input Voltages Greater than 6.0 V
NCP500, NCV500 Figure 32 Delayed Turn−on Figure 33 Delayed Turn−on Figure 34 Input Voltages Greater than 6.0 V
link to page 15
NCP500, NCV500
Input Output 1 5 1.0 mF 1.0 mF 2 Enable 3 4 Output 1 5 1.0 mF 1.0 mF 2 3 4 R C
If a delayed turn−on is needed during power up of several volt- ages then the above schematic can be used. Resistor R, and capacitor C, will delay the turn−on of the bottom regulator. A few values were chosen and the resulting delay can be seen in Figure 33. 4 3 oltage (V) 2 TA = 25°C Vin = 3.4 V 1 Vout = 2.8 V Enable V 0 3 2.5 No Delay 2 oltage (V) R = 1.0 MW V 1.5 C = 1.0 mF R = 1.0 MW 1 C = 0.1 mF Output 0.5 V out, 0 0 10 20 30 40 50 60 70 80 90 100 110 Time (ms)
The graph shows the delay between the enable signal and output turn−on for various resistor and capacitor values. Input Output Q1 1 5 R 1.0 mF 1.0 mF 2 3 4 5.6 V
A regulated output can be achieved with input voltages that ex- ceed the 6.0 V maximum rating of the NCP500 series with the addition of a simple pre−regulator circuit. Care must be taken to prevent Q1 from overheating when the regulated output (Vout) is shorted to Gnd.
www.onsemi.com 15
