Datasheet ADA4523-1 (Analog Devices) - 6
Description36 V, Low Noise, Zero Drift Op Amp
Pages / Page29 / 6 — ADA4523-1. Data Sheet. Parameter. Symbol Test Conditions/Comments. Min. …
File Format / SizePDF / 939 Kb
ADA4523-1. Data Sheet. Parameter. Symbol Test Conditions/Comments. Min. Typ. Max. Unit
ADA4523-1 Data Sheet Parameter Symbol Test Conditions/Comments Min Typ Max Unit
DYNAMIC PERFORMANCE Gain Bandwidth Product 5 MHz Slew Rate Rising SRRISE AV = −1, RL = 10 kΩ 1.85 V/µs Falling SRFALL AV = −1, RL = 10 kΩ 1.8 V/µs Internal Chopping Frequency fC 330 kHz EMI Rejection Ratio +IN EMIRR Input voltage (VIN) = −10 dBm peak, 80 dB frequency (f) = 400 MHz VIN = −10 dBm peak, f = 900 MHz 140 dB VIN = −10 dBm peak, f = 1800 MHz 90 dB VIN = −10 dBm peak, f = 2400 MHz 94 dB INPUT NOISE Spectral Density Current in 1 kHz 1 pA/√Hz Voltage en 1 kHz 4.2 nV/√Hz Voltage en P-P 0.1 Hz to 10 Hz 88 nV p-p en RMS 0.1 Hz to 10 Hz 13.3 nV rms SHUTDOWN CHARACTERISTICS −40°C ≤ TA ≤ +125°C Shutdown Threshold (SD − SDCOM) Low VSDL 0.8 V High VSDH 2 V SDCOM Voltage Range −15 +12.65 V SD Current I V − V SD SD SDCOM = 0 V −1.5 −0.5 µA SDCOM Current ISDCOM V − V SD SDCOM = 0 V 3 6 µA 1 These parameters are guaranteed by design. Thermocouple effects preclude measurements of these voltage levels during automated testing. VOS is measured to a limit determined by the test equipment capabilities. 2 The input bias current and input offset current are measured using an equivalent source impedance of 100 MΩ || 51 pF. Rev. 0 | Page 6 of 29 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TYPICAL APPLICATION DIAGRAM COMPANION PRODUCTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 5 V ELECTRICAL CHARACTERISTICS 30 V ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT VOLTAGE NOISE INPUT CURRENT NOISE INPUT BIAS CURRENT THERMOCOUPLE EFFECTS POWER DISSIPATION ELECTRICAL OVERSTRESS AND INPUT PROTECTION SHUTDOWN MODE APPLICATIONS INFORMATION PARALLELING CHOPPERS TO IMPROVE NOISE SOLDER PAD LAYOUTS TYPICAL APPLICATION CIRCUIT AND TRANSFER FUNCTION RELATED PRODUCTS OUTLINE DIMENSIONS ORDERING GUIDE
