Datasheet ADA4177-1, ADA4177-2, ADA4177-4 (Analog Devices) - 3
DescriptionOVP and EMI Protected, Precision, Low Noise and Bias Current Single Op Amp
Pages / Page33 / 3 — Data Sheet. ADA4177-1/ADA4177-2/ADA4177-4. REVISION HISTORY. 8/2018—Rev. …
RevisionE
Data Sheet. ADA4177-1/ADA4177-2/ADA4177-4. REVISION HISTORY. 8/2018—Rev. D to Rev. E. 5/2017—Rev. C to Rev. D
Data Sheet ADA4177-1/ADA4177-2/ADA4177-4 REVISION HISTORY 8/2018—Rev D to Rev E 5/2017—Rev C to Rev D
Data Sheet ADA4177-1/ADA4177-2/ADA4177-4 REVISION HISTORY 8/2018—Rev. D to Rev. E
Changes to Input Protection Circuit Section and Limiting Change to Input Capacitance (CINCM) Parameter, Table 2.. 4 Overvoltage Current Out of the Positive Supply Pin Section ... 26 Change to Input Capacitance (CINCM) Parameter, Table 3.. 6 Changes to Using the ADA4177-1/ADA4177-2/ADA4177-4 as Changes to Ordering Guide ... 33 a Comparator Section ... 27 Changes to Ordering Guide ... 31
5/2017—Rev. C to Rev. D 1/2015—Rev. A to Rev. B
Changes to Features Section, Applications Section, and General Added ADA4177-4 .. Universal Description Section ... 1 Reorganized Layout ... Universal Changes to Figure 9, Figure 10, Figure 11, Figure 12, Figure 13, Added Figure 2; Renumbered Sequentially ... 1 and Figure 14 ... 12 Changes to Features and General Description Section .. 1 Changes to Figure 15 and Figure 16 ... 13 Changes to Table 2 .. 3 Changes to Add an External Series Input Resistor Section and Changes to Table 3 .. 5 Figure 85 ... 26 Changes to Table 5 .. 7 Changes to Self Heating Section ... 28 Added Figure 6, Figure 7, and Table 7; Renumbered Added Long-Term Drift Section ... 29 Sequentially .. 9 Added Temperature Hysteresis Section, Figure 97, Figure 98, and Added Figure 10 and Figure 13 ... 10 Figure 99; Renumbered Sequentially ... 30 Replaced Figure 15 and Figure 18 ... 11 Added Figure 14, Figure 16, Figure 17, and Figure 19 ... 11
4/2015—Rev. B to Rev. C
Changes to Figure 20, Figure 21, Figure 23, and Figure 24 ... 12 Added ADA4177-1 .. Universal Changes to Figure 32 and Figure 33 ... 14 Deleted Figure 2; Renumbered Sequentially ... 1 Changes to Figure 38 and Figure 41 ... 15 Change to Table 1 .. 1 Changes to Figure 58 and Figure 61 ... 18 Added Figure 5, Figure 6, and Table 7; Renumbered Changes to Figure 62, Figure 65, and Figure 66 .. 19 Sequentially .. 9 Changes to Figure 69 and Figure 72 ... 20 Changes to Figure 16, Figure 17, Figure 19, and Figure 20 ... 12 Change to Figure 87 Caption ... 25 Changes to Figure 26 .. 14 Updated Outline Dimensions .. 27 Changes to Figure 34, Figure 35, Figure 37, and Figure 39 ... 16 Added Figure 93 and Figure 94 ... 28 Changes to Figure 46, Figure 47, Figure 49, and Figure 50 ... 17 Changes to Ordering Guide ... 29 Changes to Figure 59 and Figure 62 ... 19 Changes to Figure 63, Figure 65, Figure 66, and Figure 68 ... 20
10/2014—Rev. 0 to Rev. A
Changes to Figure 69 and Figure 72 ... 21 Changes to Large Signal Voltage Gain Parameter, Test Changes to Figure 75 and Figure 78 ... 22 Conditions/Comments Column, Table 3 ... 5 Added Figure 77 and Figure 80 ... 22 Added Figure 81 to Figure 83 .. 23
10/2014—Revision 0: Initial Version
Changes to Theory of Operation Section .. 24 Rev. E | Page 3 of 33 Document Outline Features Applications General Description Pin Connection Diagram Revision History Specifications Electrical Characteristics, ±5 V Electrical Characteristics, ±15 V Absolute Maximum Ratings Maximum Power Dissipation Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Active Overvoltage Protection Common Protection Methods Add an External Series Input Resistor Add External Clamping Diodes Input Protection Circuit Limiting Overvoltage Current Out of the Positive Supply Pin EMI Protection Self Heating Using the ADA4177-1/ADA4177-2/ADA4177-4 as a Comparator Output Phase Reversal Proper Printed Circuit Board (PCB) Layout Long-Term Drift Temperature Hysteresis Outline Dimensions Ordering Guide
