Datasheet ADA4177-1, ADA4177-2, ADA4177-4 (Analog Devices) - 10
DescriptionOVP and EMI Protected, Precision, Low Noise and Bias Current Single Op Amp
Pages / Page33 / 10 — ADA4177-1/ADA4177-2/ADA4177-4. Data Sheet. OUT A 1. –IN A. ADA4177-2. OUT …
RevisionE
ADA4177-1/ADA4177-2/ADA4177-4. Data Sheet. OUT A 1. –IN A. ADA4177-2. OUT B. –IN A 2. ADA4177-2 7 OUT B. TOP VIEW. +IN A. –IN B
ADA4177-1/ADA4177-2/ADA4177-4 Data Sheet OUT A 1 –IN A ADA4177-2 OUT B –IN A 2 ADA4177-2 7 OUT B TOP VIEW +IN A –IN B
ADA4177-1/ADA4177-2/ADA4177-4 Data Sheet OUT A 1 8 V+ OUT A 1 8 V+ –IN A ADA4177-2 2 7 OUT B –IN A 2 ADA4177-2 7 OUT B TOP VIEW +IN A 3 6 –IN B (Not to Scale) +IN A 3 TOP VIEW 6 –IN B
004
(Not to Scale)
005
V– 4 5 +IN B V– 4 5 +IN B
12282- 12282- Figure 5. ADA4177-2 8-Lead MSOP Pin Configuration Figure 6. ADA4177-2 8-Lead SOIC Pin Configuration
Table 7. ADA4177-2 P in Function Descriptions Pin No. Mnemonic Description
1 OUT A Output Channel A. 2 −IN A Inverting Input Channel A. 3 +IN A Noninverting Input Channel A. 4 V− Negative Supply Voltage. 5 +IN B Noninverting Input Channel B. 6 −IN B Inverting Input Channel B. 7 OUT B Output Channel B. 8 V+ Positive Supply Voltage. Rev. E | Page 10 of 33 Document Outline Features Applications General Description Pin Connection Diagram Revision History Specifications Electrical Characteristics, ±5 V Electrical Characteristics, ±15 V Absolute Maximum Ratings Maximum Power Dissipation Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information Active Overvoltage Protection Common Protection Methods Add an External Series Input Resistor Add External Clamping Diodes Input Protection Circuit Limiting Overvoltage Current Out of the Positive Supply Pin EMI Protection Self Heating Using the ADA4177-1/ADA4177-2/ADA4177-4 as a Comparator Output Phase Reversal Proper Printed Circuit Board (PCB) Layout Long-Term Drift Temperature Hysteresis Outline Dimensions Ordering Guide
