Datasheet ADA4084-1, ADA4084-2, ADA4084-4 (Analog Devices) - 9
Description30 V, Low Noise, Rail-to-Rail Input/Output, Low Power Operational Single Amplifier
Pages / Page36 / 9 — Data Sheet. ADA4084-1/ADA4084-2/ADA4084-4. ADA4084-2. OUT A 1. 8 V+. –IN …
RevisionI
Data Sheet. ADA4084-1/ADA4084-2/ADA4084-4. ADA4084-2. OUT A 1. 8 V+. –IN A 2. 7 OUT B. +IN A 3. 6 –IN B. V– 4. 5 +IN B. TOP VIEW
Data Sheet ADA4084-1/ADA4084-2/ADA4084-4 ADA4084-2 OUT A 1 8 V+ –IN A 2 7 OUT B +IN A 3 6 –IN B V– 4 5 +IN B TOP VIEW
Data Sheet ADA4084-1/ADA4084-2/ADA4084-4 ADA4084-2 OUT A 1 8 V+ OUT A 1 8 V+ –IN A 2 7 OUT B –IN A 2 7 OUT B +IN A 3 6 –IN B +IN A 3 6 –IN B V– 4 5 +IN B V– 4 5 +IN B
03 3
TOP VIEW
7-
ADA4084-2
23
(Not to Scale)
302 08
TOP VIEW
8237-
(Not to Scale)
0 Figure 7. ADA4084-2, 8-Lead SOIC (R) Figure 6. ADA4084-2, 8-Lead MSOP (RM)
Table 10. 8-Lead MSOP, 8-Lead SOIC, ADA4084-2 Pi n Function Descriptions Pin No. Mnemonic Description
1 OUT A Output, Channel A 2 −IN A Negative Input, Channel A 3 +IN A Positive Input, Channel A 4 V− Negative Supply 5 +IN B Positive Input, Channel B 6 −IN B Negative Input, Channel B 7 OUT B Output, Channel B 8 V+ Positive Supply B
OUT A 1 14 OUT D –IN A 2 13 –IN D +IN A 3 12 +IN D ADA4084-4 V+ 4 11 V– TOP VIEW (Not to Scale) +IN B 5 10 +IN C –IN B 6 9 –IN C
2
OUT B 7 8 OUT C
10 37- 82 0 Figure 8. ADA4084-4, 14-Lead TSSOP (RU)
Table 11. 14-Lead TSSOP, ADA4804-4 Pi n Function Descriptions Pin No. Mnemonic Description
1 OUT A Output, Channel A 2 −IN A Negative Input, Channel A 3 +IN A Positive Input, Channel A 4 V+ Positive Supply 5 +IN B Positive Input, Channel B 6 −IN B Negative Input, Channel B 7 OUT B Output, Channel B 8 OUT C Output, Channel C 9 −IN C Negative Input, Channel C 10 +IN C Positive Input, Channel C 11 V− Negative Supply 12 +IN D Positive Input, Channel D 13 −IN D Negative Input, Channel D 14 OUT D Output, Channel D Rev. I | Page 9 of 36 Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS ±1.5 V CHARACTERISTICS ±5 V CHARACTERISTICS ±15 V CHARACTERISTICS APPLICATIONS INFORMATION FUNCTIONAL DESCRIPTION START-UP CHARACTERISTICS INPUT PROTECTION OUTPUT PHASE REVERSAL DESIGNING LOW NOISE CIRCUITS IN SINGLE-SUPPLY APPLICATIONS COMPARATOR OPERATION LONG-TERM DRIFT TEMPERATURE HYSTERESIS OUTLINE DIMENSIONS ORDERING GUIDE
