ADA4084-1/ADA4084-2/ADA4084-4Data SheetPIN CONFIGURATIONS AND FUNCTION DESCRIPTIONSNIC18NIC–IN2ADA4084-1 7 V++IN3TOP VIEW6OUT(Not to Scale)V–45NIC 101 NOTES 1. NIC = NOT INTERNALLY CONNECTED. 08237- Figure 3. ADA4084-1, 8-Lead SOIC (R) Table 7. 8-Lead SOIC, ADA4084-1 Pin Function Descriptions Pin No.Mnemonic Description 1 NIC Not Internally Connected 2 −IN Negative Input 3 +IN Positive Input 4 V− Negative Supply 5 NIC Not Internally Connected 6 OUT Output 7 V+ Positive Supply 8 NIC Not Internally Connected ADA4084-1OUT 15V+V– 2 301 +IN 34–IN 08237- Figure 4. ADA4084-1, 5-Lead SOT-23 (RJ) Table 8. 5-Lead SOT-23, ADA4084-1Pin Function Descriptions Pin No.Mnemonic Description 1 OUT Output 2 V− Negative Supply 3 +IN Positive Input 4 −IN Negative Input 5 V+ Positive Supply OUT A 18 V+–IN A 27 OUT BADA4084-2+IN A 3TOP VIEW6 –IN B(Not to Scale)V– 45 +IN BNOTES 1. FOR THE LFCSP PACKAGE, 104 THE EXPOSED PAD MUST BE CONNECTED TO V–. 08237- Figure 5. ADA4084-2, 8-Lead LFCSP (CP) Table 9. 8-Lead LFCSP, ADA4084-2 Pin Function Descriptions Pin No.Mnemonic Description 1 OUT A Output, Channel A 2 −IN A Negative Input, Channel A 3 +IN A Positive Input, Channel A 4 V− Negative Supply 5 +IN B Positive Input, Channel B 6 −IN B Negative Input, Channel B 7 OUT B Output, Channel B 8 V+ Positive Supply EPAD Exposed Pad. For the LFCSP package, the exposed pad must be connected to V−. Rev. I | Page 8 of 36 Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS ±1.5 V CHARACTERISTICS ±5 V CHARACTERISTICS ±15 V CHARACTERISTICS APPLICATIONS INFORMATION FUNCTIONAL DESCRIPTION START-UP CHARACTERISTICS INPUT PROTECTION OUTPUT PHASE REVERSAL DESIGNING LOW NOISE CIRCUITS IN SINGLE-SUPPLY APPLICATIONS COMPARATOR OPERATION LONG-TERM DRIFT TEMPERATURE HYSTERESIS OUTLINE DIMENSIONS ORDERING GUIDE
