Datasheet ADA4665-2-KGD (Analog Devices) - 4
Description16 V, 1.2 MHz, CMOS Rail-to-Rail Input/Output Operational Amplifier
Pages / Page8 / 4 — ADA4665-2-KGD. Known Good Die. Parameter. Symbol. Test …
File Format / SizePDF / 211 Kb
ADA4665-2-KGD. Known Good Die. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max Unit
ADA4665-2-KGD Known Good Die Parameter Symbol Test Conditions/Comments Min Typ Max Unit
NOISE PERFORMANCE Voltage Noise en p-p Frequency = 0.1 Hz to 10 Hz 3 µV p-p Voltage Noise Density en Frequency = 1 kHz 32 nV/√Hz Frequency = 10 kHz 27 nV/√Hz Current Noise Density in Frequency = 1 kHz 50 fA/√Hz Rev. 0 | Page 4 of 8 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—16 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTION OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
