Datasheet AD8011 (Analog Devices)
Description | 300 MHz Current Feedback Amplifier |
Pages / Page | 16 / 1 — 300 MHz. Current Feedback Amplifier. AD8011. FEATURES. FUNCTIONAL BLOCK … |
Revision | C |
File Format / Size | PDF / 224 Kb |
300 MHz. Current Feedback Amplifier. AD8011. FEATURES. FUNCTIONAL BLOCK DIAGRAM. Easy to Use. 8-Lead PDIP and SOIC
300 MHz Current Feedback Amplifier AD8011 FEATURES FUNCTIONAL BLOCK DIAGRAM Easy to Use 8-Lead PDIP and SOIC Low Power 1 mA Power Supply Current (5 mW on 5 VS) High Speed and Fast Settling on 5 V NC 1 8 NC 300 MHz, –3 dB Bandwidth (G = +1) –IN 2 7 V+ 180 MHz, –3 dB Bandwidth (G = +2) 2000 V/
s Slew Rate +IN 3 6 OUT 29 ns Settling Time to 0.1% 4 V– 5 NC AD8011 Good Video Specifications (RL = 1 k
, G = +2) Gain Flatness 0.1 dB to 25 MHz NC = NO CONNECT 0.02% Differential Gain Error 0.06
ⴗ
Differential Phase Error PRODUCT DESCRIPTION Low Distortion
The AD8011 is a very low power, high speed amplifier designed
–70 dBc Worst Harmonic @ 5 MHz
to operate on +5 V or ± 5 V supplies. With wide bandwidth,
–62 dBc Worst Harmonic @ 20 MHz
low distortion, and low power, this device is ideal as a general-
Single Supply Operation
purpose amplifier. It also can be used to replace high speed
Fully Specified for 5 V Supply
amplifiers consuming more power. The AD8011 is a current feed-
back amplifier and features gain flatness of 0.1 dB to 25 MHz
Power Sensitive, High Speed Systems
while offering differential gain and phase error of 0.02% and 0.06°
Video Switchers
on a single 5 V supply. This makes the AD8011 ideal for profes-
Distribution Amplifiers
sional video electronics such as cameras, video switchers, or any
A-to-D Driver
high speed portable equipment. Additionally, the AD8011’s low
Professional Cameras
distortion and fast settling make it ideal for buffering high speed
CCD Imaging Systems
8-, 10-, and 12-bit A-to-D converters.
Ultrasound Equipment (Multichannel)
The AD8011 offers very low power of 1 mA maximum and can run on single 5 V to 12 V supplies. All this is offered in a small 8-lead PDIP or 8-lead SOIC package. These features fit well with
5
portable and battery-powered applications where size and power
G = +2
are critical.
4 RF = 1k
V
The AD8011 is available in the industrial temperature range of
3 S = +5V OR
ⴞ
5V VOUT = 200mV p-p
–40°C to +85°C.
2 1 –40 0 G = +2 THIRD –1 RL = 150
–2 NORMALIZED GAIN (dB) –3 –60 SECOND R –4 L = 150
–5 1 10 100 500 DISTORTION (dBc) FREQUENCY (MHz) –80 THIRD
Figure 1. Frequency Response; G = +2, V
RL =1k
⍀ S = +5 V, or ±5 V
SECOND RL = 1k
–100 10 20 FREQUENCY (MHz)
REV. C Figure 2. Distortion vs. Frequency; VS = ±5 V Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. No license is granted by implication or otherwise
under any patent or patent rights of Analog Devices. Trademarks and
Tel: 781/329-4700 www.analog.com
registered trademarks are the property of their respective companies.
Fax: 781/326-8703 © 2003 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM PRODUCT DESCRIPTION SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ORDERING GUIDE Typical Performance Characteristics THEORY OF OPERATION DC GAIN CHARACTERISTICS AC TRANSFER CHARACTERISTICS DRIVING CAPACITIVE LOADS OPTIMIZING FLATNESS INCREASING BW AT HIGH GAINS DRIVING A SINGLE-SUPPLY A/D CONVERTER LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS Revision History
