link to page 13 Data SheetOP200DUAL 12-BIT VOLTAGE OUTPUT DACDUAL PRECISION VOLTAGE REFERENCE The dual output DAC shown in Figure 33 is capable of providing A dual OP200 and a REF43, a 2.5 V reference, can be used to untrimmed 12-bit accurate operation over the entire military build a ±2.5 V precision voltage reference. Maximum output temperature range. Offset voltage, bias current, and gain errors current from each reference is ±10 mA with load regulation of the OP200 contribute less than 1/10 of an LSB error at 12 bits under 25 μV/mA. Line regulation is better than 15 μV/V and over the military temperature range. output voltage drift is under 20 μV/°C. Output voltage noise from 0.1 Hz to 10 Hz is typically 75 μV p-p. R1 and D1 ensure correct startup. 5V21VDDRFB A 38DAC822110VVDAC AI4REF AREFERENCE1/2OUT A 22VOLTAGEDAC82211/21OP200AZOUT A34V–DAC DATA BUSPIN 6 (MSB) TO PIN 17 (LSB)RFB B 2322 VREF BDAC BIOUT B 2461/2DAC82211/27OP200AZOUT B518DAC A/DAC BAGND 119DACCONTROLCS20WRDGND 3 03 5 2- 32 00 Figure 33. Dual 12-Bit Voltage Output DAC +5VR122kΩD11N914+2.5V+5VR310kΩVIN 2628VR3OUT1/2110kΩ6REF43OP200AZ51/237TRIMOP200AZ45GND 4R45kΩ–5V 34 -0 22 –2.5V 030 Figure 34. Dual Precision Voltage Reference Rev. G | Page 13 of 16 Document Outline FEATURES PIN CONNECTIONS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION DUAL LOW POWER INSTRUMENTATION AMPLIFIER PRECISION ABSOLUTE VALUE AMPLIFIER PRECISION CURRENT PUMP DUAL 12-BIT VOLTAGE OUTPUT DAC DUAL PRECISION VOLTAGE REFERENCE PROGRAMMABLE HIGH RESOLUTION WINDOW COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
